What internally could causes surge at idle
My 416 started to feel like it had surge. Shortly after that I noticed at night the dash lights & head lights flickered or surged. The surge gradually got worse.
My car's issue was the alternator was failing. The voltage regulator was bad. New alternator fixed the issue. I also had to replace the battery shortly before the alternator issue. I'm guessing the bad alternator helped kill my 2 year old battery. Not saying that is your car's issue.
Wish you the best with troubleshooting your ride. Sounds like a sweet set with cam & intake etc!
Also, how is your PCV routed? There needs to be a restriction in it, fixed orifice. PCV air also needs to be accounted for (measured) if you are running a mass air meter.
I will get with my tuner about adjusting the damping factor and see if that’s something he’s looked at. I’m not running a mass air meter. Thanks for the help.
I'm not familiar with GM ECM idle settings, but my Holley ECM allows me to adjust the PID settings for idle spark control and IAC. Lumpy cams bounce by nature and you gotta slow down ECM decision making by adjusting PID settings, and range of allowable RPM swing to remain in idle control mode. There's got to be something similar in the GM ECM to get the ECM to chill out a bit and stop trying to make idle adjustments so fast.
As always, tuning idle is never really possible without first setting the base airflow correctly with throttle stop screw. Then the real tuning can begin. Tuning idle is actually one of the most difficult tasks a tuner encounters. If your tuner can't figure it out then don't even hesitate to try somebody else until you find somebody that can.
pump and filter about 3 months ago. Thanks though.
