430" ls7
LLSR Cam Motion, 265/283 @ .050" .720"/.710" 113lsa
13.8:1
BR7 heads ported by Frankenstein w/ Crower 1.8 shaft rockers
CID 4.5
1050 Dominator
Heading to the flywheel dyno soon....
For what this is capable of making, the 5.3L is plenty good enough and a light alternative to an a/m iron block. Most all aftermarket 4" cranks have gun-drilled mains like a factory LS2/3 crank. Bay to bay breathing doesn't seem too bad for what a 4" crank engine normally produces compared to one with an early non-drilled crank. I wouldn't hesitate to do a 5.3L sleeve build for any NA effort. I wouldn't sacrifice a nice LS2 to sleeve unless the bores were beyond use, those blocks are getting harder to find in nice condition and are plenty strong for most boosted street/strip builds (they are light too!).
I will know in a couple of weeks. This doesn't have the aggressive camshaft/valvetrain that one did due to these heads being built for a hydraulic roller to start with. I converted them to a solid valvetrain. The BR7's don't have the BS 'big spring' pockets limiting the cam selection I could go with. The shaft rocker set up uses the smaller 8mm stand bolts, so the 1238X springs are about the limit, limiting the lobe lift. This one also has steel valves, but the port work is pretty nice. They have 282cc intake ports. 2.250" intake valves, 1.610" exh valves. Advertised flow numbers are strong everywhere.
