Cam numbers help
(used to run only nitrous engines 1st time doing a boosted)
LY6 Block, Callies Crank 4.100 & 6.125 H rods, 4.030 JE pistons -14CC, 1.7 Jessel Rocker Arms & lifters, STOCK HEADS for now.
@50 243/258
Lift .623/6.15
116 LSA install at 112.
Any other recomendations?
thanks in advance.
Some more information about what you intend to use it for might get you some better suggestions.
Car will be a 90% track and 10% street.
Car is about 2500 Lbs.
Car should be running either 100 yards and hoping to close aoout 7800RPMs.
Everything on the car is "designed" to be boosted but still almost 20 degrees of overlap for the cam??
Let me know if need more info.
I have not asked Cam Motion, I suspect they’d be more forthcoming. I’d like the information in order to better calculate the DCR on any cam I’m considering putting in my pump gas 11.8 CR engine.
