Pushrod length help ls3
So the problem I'm running into is my intake pushrod measures 7.335 0 lash and exhaust is 7.354 0 lash I've measured all cylinder across the block and all measure roughly the same is that normal and also what pushrod should I run I ordered btr 7.400 but when I measured them there 7.420 🤦♂️. Should I run these on intake and do 80 preload and buy some btr 7.420 and hope there off by 20 to make 7.440 and run those on exhaust to be 80 preload aswell
Thanks...
Yh it's so weird I've read somewhere that it's normal on ls3 but not sure ive ran it for a while on the 7.4 since its pretty much still in the ok preload range for the lifters but after a year I started getting a tick put new lifters in it but still has the tick so now I'm guessing it might be the pushrods its not supper loud like a rod bearing or anything crazy and it's driving me nuts 🤦♂️
https://ls1tech.com/forums/generation-iii-internal-engine/1521230-2-different-pushrod-lengths.html
I'm going to be tearing mine apart
The split of the two PR lengths between the intake and exhaust comes out to be 7.425 so I probably wouldn't be worried about running the 7.420 PR as it would fall into this +/- 0.010 range. My .02
