418ci
Old May 2, 2023 | 12:24 PM
SmtlR/T's Avatar
Default I'm about to build a 418ci with a 4.100 stroke crankshaft, and 4.030 pistons, 6.125"
I'm about to build a 418ci with a 4.100 stroke crankshaft, and 4.030 pistons, 6.125" connecting rod. What can you tell me about this project
Old May 2, 2023 | 12:31 PM
SmtlR/T's Avatar
Default 418ci
Old May 2, 2023 | 12:34 PM
wretched73's Avatar
I think you mean, what can YOU tell us about this project?
Old May 2, 2023 | 12:38 PM
SmtlR/T's Avatar
I would like to know if someone has built a stroker like this and how it worked or if they had any complications
Old May 2, 2023 | 06:45 PM
Utinator's Avatar
Board moderator KCS has built something similar to that. Quiktrip has also built something like that. Check out this discussion: https://ls1tech.com/forums/generatio...ed-stroke.html
That might give you some ideas of what to expect.
Old May 2, 2023 | 06:46 PM
Utinator's Avatar
Check your other thread about this.
Old May 4, 2023 | 07:13 AM
Double06's Avatar
Make sure your block has adequate sleeve length for the 4.10 inch stroke also helps if piston company knows the sleeve length too. Might want to talk to Diamond pistons on this issue.
