Need to do a plug and wire change for an LSA (first time)
Old May 25, 2023 | 08:23 AM
sbelyo's Avatar
Default Need to do a plug and wire change for an LSA (first time)
Hi All...
I just bought a 2013 ZL1 this week with 60K on the clock. From what I can tell there are long tube headers, a 2.5 inch top pulley, and a CAI. I have no idea of the size of the crank pulley.
I'd like to to a plug change and need to know what the torque specs are on the plug and from what I read the TR6 plug is the way to go. Normally I would lube the boot and plug with electrolytic grease the put anti seize on the threads then torque to spec. Is this still ok?
What should I use for a gap?
I have an inch pound torque wrench, swivels, extensions, and spark plug sockets. Do I need anything else?
Old May 25, 2023 | 05:43 PM
Personally, I’d go back with whatever plug is in it and I would mimick the same gap. Heck, with 60k miles, I bet plugs still look great. Pull one and see if it’s a waste of time to touch them before you go get a new set..
Old May 26, 2023 | 07:37 AM
sbelyo's Avatar
I hear you, its just a ritual I go through whenever I buy a used car. I hate not know what when and where things like plugs and filters were replaced. I noticed a tear in one of the plug boots and it has a slight stumble from time to time. I figured that's a good excuse to do a tune up.
It looks like the gap is 0.04 or 1 mm. Not sure what the torque spec is yet.
Old May 26, 2023 | 08:09 AM
02EBC5Z06's Avatar
DO NOT put antisieze on the plugs. Put them in dry
Old May 26, 2023 | 09:01 AM
sbelyo's Avatar
got it, no Anti-Seize. Any indea on the torque spec?
Old May 26, 2023 | 09:03 AM
02EBC5Z06's Avatar
Snug... 1/4 turn. That is it.
Old May 26, 2023 | 12:36 PM
sbelyo's Avatar
sounds good. I've always been crazy about it since I had a 2001 mustang and the aluminum heads only had three thread revolutions to hold the plug in so you couldn't over tighten them
Old May 28, 2023 | 02:03 PM
Jimbo1367's Avatar
are you serious? That’s not what I’d do. Damn lol
Old May 28, 2023 | 11:49 PM
Keith's Avatar
https://ngksparkplugs.com/en/resourc...ut-spark-plugs
Old May 30, 2023 | 08:26 PM
sbelyo's Avatar
Here's what the chilton manual says on torque specs
Tighten the spark plugs. Tighten the engine spark plug on a NEW cylinder head to 20 N·m (15 lb ft) and the engine spark plug on subsequent installations to 15 N·m (11 lb ft)
Old May 30, 2023 | 08:27 PM
sbelyo's Avatar
double post
Old May 30, 2023 | 08:29 PM
02EBC5Z06's Avatar
This ain't 1980 anymore lol...
Old May 31, 2023 | 07:59 AM
01CamaroSSTx's Avatar
Not sure I'll still continue to use anti-sieze on my plugs and I don't use the tq on spark plugs either and prefer to go by feel. Learn something new everyday.
Old May 31, 2023 | 04:51 PM
old motorhead's Avatar
AC Delco 41-104 spark plugs are factory fill for C6 Z06 and C6 ZR1 engines. I've been using them for years to over 660 rwhp. N/A and supercharged. They come ready to install. Nothing wrong with the stock plug wires either. If you feel the burning need to install something different, by all means, do it. I do put a little dab of never sneeze on the threads too. Wrist tight. I've had TR6's bad from the factory. Never a problem with the 41-104's.
If you change plugs often, maybe the TR6's fit your program. If you're the screw them in and worry about something else type, the AC Delco's are a better deal.
Old Jun 5, 2023 | 07:53 AM
99 Black Bird T/A's Avatar
Nice to know things evolved and anti-seize isn't absolutely necessary with NKG's.
FWIW - always used very thin film of anti-seize on the ~8 plug plugs my 99 T/A had with no issues. Normally GM LS aluminum heads have a plug torque of 15 foot pounds new and 11 foot pounds there afterwards. l always used a torque wrench not having those mad mechanical skills & feels to play it safe.
Old Jun 5, 2023 | 02:09 PM
Jimbo1367's Avatar
thanks. I never heard that before. Is it a common practice from all of the plug manufacturers nowadays?
I remember a car came into our shop when I was 18/19 that her B/F changed the plugs. It was running on three while the forth plug was hanging from the plug wire. He stripped it out. Lol.
Old Jun 5, 2023 | 04:18 PM
Keith's Avatar
I'm not sure, I've always used a dab of anti-seize. Then a year or so ago I read that and I guess I've been doing it wrong, lol.
Old Jun 5, 2023 | 04:20 PM
02EBC5Z06's Avatar
I've never put anti sieze on any ngk plug. And I've put hundreds of plugs through my engine.
Old Jun 7, 2023 | 03:41 PM
sbelyo's Avatar
Going to wind up having a shop do them. Took it to a tuner today and when he took it for a drive the injector duty cycles went up to 126% so they're going to change the fuel pump. While its there I'll have them tune it and change the plugs. At least it'll be safe now and feel much better
