L76 - while I'm in there
Hey guys,
This week sadly my L76 swapped FRS experienced a oil starvation issue - resulting in rod knock. I'm in the process of tearing it down to see the damage.
While I've got the whole top and bottom end torn apart, are there any parts you'd reccomend replacing while I'm in there?
Mods:
BTR Stage 2 LS3 Cam
LS7 lifters
Trunion kit
Btr dual valve springs
Btr rods
Ls2 timing chain
Upgraded oil pump
Ati harmonic balancer
Ls1 oil pan with improved racing baffle
Dyno'd 462 whp
Stock heads
Stock intake
Stock throttle body
Stock bottom end
Likely going to tackle new rod bearings, new cam bearing and replace the crank and/or rods depending on how bad they are. Praying the block is OK. Thinking about getting the rotating assembly balanced and maybe porting the heads if I can get that done locally.
Car is daily driven, but building slighty toward drift and light track time.
Thanks for any suggestions you have!
Mods:
BTR Stage 2 LS3 Cam
LS7 lifters
Trunion kit
Btr rods
Ls2 timing chain
Upgraded oil pump
Dyno'd 462 whp
Stock heads
Stock intake
Stock throttle body
Stock bottom end
Hey guys,
Mods:
BTR Stage 2 LS3 Cam
LS7 lifters
Trunion kit
Btr rods
Ls2 timing chain
Upgraded oil pump
Dyno'd 462 whp
Stock heads
Stock intake
Stock throttle body
Stock bottom end
Mods:
BTR Stage 2 LS3 Cam
LS7 lifters
Trunion kit
Btr rods
Ls2 timing chain
Upgraded oil pump
Dyno'd 462 whp
Stock heads
Stock intake
Stock throttle body
Stock bottom end
The following users liked this post:
Matt_liil (05-28-2023)
I would consider some sort of oil pan baffling like Improved Racing if they make one to fit your pan. It seems like a good idea since you plan on tracking this eventually
Ironically, I just added the improved racing baffle to my pan 3 days prior to the starvation issue. Just got around to pulling off the pan to check and make sure the doors were still moving, and they were. That was the only recent addition to the motor latrly, so I had really though that was the issue.
Hey guys,
Mods:
BTR Stage 2 LS3 Cam
LS7 lifters
Trunion kit
Btr rods
Ls2 timing chain
Upgraded oil pump
Dyno'd 462 whp
Stock heads
Stock intake
Stock throttle body
Stock bottom end
Mods:
BTR Stage 2 LS3 Cam
LS7 lifters
Trunion kit
Btr rods
Ls2 timing chain
Upgraded oil pump
Dyno'd 462 whp
Stock heads
Stock intake
Stock throttle body
Stock bottom end
Che70velle (06-01-2023)
