Can you replace a big CAM with a stock CAM
Old Jun 20, 2023 | 05:56 PM
Flyguy's Avatar
Default Can you replace a big CAM with a stock CAM
I am looking to lower the power (yes not typical) in a LH6. The CAM spec's are 223/231 at .050 in .610/.617 lift with 112 LSA.The current CAM has output of 475HP/435TQ. (https://www.speedwaymotors.com/LS-Crate-Engine-Chevy-LH6-5-3L-475HP-435TQ,497805.html ). This engine has upgraded valve springs as well.
I am thinking of something like 190/191 at .050 in, .457/.466 and 115.5 LSA (Similar to a stock LM7). I'm very open to what CAM, but will be mindful of cost. The current CAM is too much power for my application, an airplane. I need ~300 hp @ 4500 RPM and I won't run the RPM any higher than 4500. I don't know, but googling the CAM specs leads me to CompCams ( https://www.compcams.com/lsr-cathedral-port-223-231-hydraulic-roller-cam-for-gm-ls-gen-iii-iv.html ). Assuming (?) that to be the case, this is a 3 bolt CAM. The Stock CAM can be either a one bolt or 3 bolt.
So my questions are:
1) What CAM should I use to bring the power down to 300 Hp @ 4500 RPM?.
2) Do I need to swap out the valve springs. I have received both yes and no answers to this question from parts shops. There are some Youtube video's by Richard Holdener that suggest bigger springs does not impact power output.
3) If it is a 3 bolt CompCam and the replacement CAM is a 1 bolt, is it as simple as replacing the CAM timing sprocket I think????
Input appreciated!
Rick
Old Jun 20, 2023 | 06:22 PM
dixiebandit69's Avatar
Just stick the factory cam in in and re-tune for the changes in volumetric efficiency.
Your existing valve springs should be fine, assuming that they don't have really high hours on them.
Since you don't know what cam bolt pattern you have, just replace the chain/ sprocket with what you already have once you take the cover off. Or reuse it. It may still be good.
This has got to be one of the first ever "I need LESS power!" posts on this board...
Why do you want less power, anyway?
Old Jun 20, 2023 | 08:38 PM
wannafbody's Avatar
Only you know if you have the skill level to replace a cam.
Old Jun 20, 2023 | 08:43 PM
Flyguy's Avatar
The engine is going to be used on an aircraft and the prop can only handle up to 300 HP.
Old Jun 21, 2023 | 01:25 AM
If you still have the original LH6 cam, put it back in.
The earlier ones (05-06) came with the L33 cam (193/193, .482/.482, 116 LSA)
After that they were- 196/201, .481/.481, 116+2 LSA
Old Jun 21, 2023 | 01:37 AM
spanks13's Avatar
Maybe consider a v6 instead to shave some weight off and be closer to your target power level?
Stock cam and valve springs all the way. Get a 3 bolt cam.
Old Jun 21, 2023 | 06:33 AM
old motorhead's Avatar
The prop can only handle 300 HP or is it the gearbox?
Old Jun 21, 2023 | 09:12 AM
Flyguy's Avatar
The Gearbox can handle up to 700 HP, but the Prop has a 300 HP limit. With a 300 HP engine and prop my airspeed is a max of 163 mph. But I won't know what power setting for that until I get in the air.
Old Jun 21, 2023 | 09:13 AM
Flyguy's Avatar
Thanks Atsma, VERY helpful.
Old Jun 21, 2023 | 11:13 AM
ddnspider's Avatar
The existing cam can be detuned to whatever power level you want. If you insist on running a smaller cam I'd get a truck cam before going to a stock cam.
Old Jun 21, 2023 | 11:27 AM
Flyguy's Avatar
Now that I review feedback some thoughts. I don't have the old CAM's. But looking for a replacement I need to be mindful that the original CAM's were for DOD engines. Not something I want. I need to find a CAM similar to what G Atsma has suggested that is a non-DOD CAM. Something like the L33 or LH8 CAM. From the feedback I sense that others don't have an issue with the bigger valve springs. The people at ComCams indicated that their bigger CAM would use springs with a close pressure of 125 lbs (at 1.8") and an open pressure of 367 lbs (at 1.15"), and a rate of 372 lbs/inch. I won't be opening as far (.485" vs .610") far so less pressure, perhaps 280-300 lbs. I don't know what stock LH6 spring pressures are, but other reading suggests that these numbers are ok. THoughts?
Rick
Old Jun 21, 2023 | 11:57 AM
grinder11's Avatar
I am looking to lower the power (yes not typical) in a LH6. The CAM spec's are 223/231 at .050 in .610/.617 lift with 112 LSA.The current CAM has output of 475HP/435TQ. (https://www.speedwaymotors.com/LS-Cr...TQ,497805.html ). This engine has upgraded valve springs as well.
I am thinking of something like 190/191 at .050 in, .457/.466 and 115.5 LSA (Similar to a stock LM7). I'm very open to what CAM, but will be mindful of cost. The current CAM is too much power for my application, an airplane. I need ~300 hp @ 4500 RPM and I won't run the RPM any higher than 4500. I don't know, but googling the CAM specs leads me to CompCams ( https://www.compcams.com/lsr-cathedr...en-iii-iv.html ). Assuming (?) that to be the case, this is a 3 bolt CAM. The Stock CAM can be either a one bolt or 3 bolt.
Input appreciated!
Rick
I'm hoping your prop is rated a bit conservatively. Why? Because you'll likely exceed 300hp with an LS type engine, unless its a 4.8 or earlier 5.3. Have no idea what props cost, but you may want to upgrade that a tad. Bottom line here is you're playing with dynamite. I'm sorry, but if that prop shreds, your life is at stake here. For that reason, I cant make any recommendation. There must be aircraft guys who would know more exact components required. Like aircraft magazines, or clubs, or someone who has actually done this. You are aware that aircraft tolerances are much more demanding than automobile tolerances, I hope? The aircraft engines I've seen have 2 ignition systems, in case one fails, and throttle bodies with integral warmers to eliminate chances of icing. Many aircraft mechanical components have a tolerance of +-.00005", thats 50 millionths of an inch!!! Your life, but I'd be VERY CAREFUL......
Old Jun 21, 2023 | 12:27 PM
grinder11's Avatar
Also, valvesprings should be matched to the cam specs. Sure, the stiffer springs you likely have to support the more aggressive cam will work. But that doesn't mean they're an ideal match. Reliability wise, I'm sure at a 4,500 rpm ceiling just about any spring will live. But you'll lose efficiency due to more friction than you'd have with matching springs. Curious about the 4,500 rpm ceiling. How is that governed, by you and the tach, or a governor?
Old Jun 21, 2023 | 12:35 PM
Flyguy's Avatar
Grinder11,
I understand the root of your concern and appreciate it. However, consider that this is not something new. Below are a few links to LS based planes as an FYI. The last link is for AutoPSRU that is a group that makes gear-boxes for BMW and LS engines. The link is a map of where they have product placed. I am not using their gear box, but an gearbox made by Stinger that is designed for aircraft. Stinger also makes airboat gearboxes.
http://www.moosemods.com/
http://www.sdsefi.com/gm.htm
https://www.v8seabee.com/
https://www.google.com/maps/d/viewer...6dDTRtfAC0ISF4
To your question regarding prop. Yes it is a 5.3L engine. The gear box and the prop are actually rated at 700 HP. But if I put a 700 HP engine/prop on the plane it will rip the wings off! To simplify dialog here I have stated 300 HP as the max for the prop and engine, but the facts are it is really the airframe. So YES, I am taking a conservative approach. But thank you for your comment and concern.
Old Jun 21, 2023 | 12:39 PM
Flyguy's Avatar
Grinder11,
To your question regarding governing the 4500 RPM. That is something that I will be able to program into the ECU. (http://www.sdsefi.com/index.html )
Rick
Old Jun 21, 2023 | 04:59 PM
As Grinder mentioned, you want to run only as much spring as necessary here, from a reliability standpoint, as well as a friction standpoint also. Friction adds heat. More spring rate adds heat to the oil. A set of Oem valvesprings can easily go 750k miles on the street, and are extremely reliable.
I feel that Spiders comments above about simply de-tuning this thing down should be considered also, as it adds economy and reliability to any engine to use less fuel and spark timing advance to make power. Just something to consider I suppose. Either way, we’ve had a few of these aviation builds here on Tech, and I always enjoy them a lot.
Old Jun 22, 2023 | 12:23 PM
Flyguy's Avatar
Scott (and others Grinder, Atsma, Snipper), thank you for your comments. I have had similar advice from another source that has done LS conversions for airplanes. They also mentioned that a stock LS CAM is not as tough (hard steel) as a performance CAM. As a result running a stock CAM with larger springs might cause premature wear of the CAM surfaces, more heat, etc. They also suggested when swapping the CAM to revert to lower pressure (stock) springs I will also look into the de-tuning. I am considering either the FiTech or the Simple Digital Systems ECU. Both are used in airplanes today.
Old Jun 22, 2023 | 01:44 PM
Cam-wise, one thing to possibly look at is camming it so peak torque happens at cruising engine RPM.
That should lend itself to peak efficiency, if it's possible to achieve.
Old Jun 22, 2023 | 10:41 PM
68Formula's Avatar
If you're worried about cam wear and looking for peak torque, I'd custom order a Cam Motion with 198/206 113+4 .527/.527 specs on an 8620 core.
I haven't heard of SDS system, but FITech doesn't seem as reliable as the Holley Sniper. But as for reliability, I don't think you can beat the factory ECU.
Old Jun 22, 2023 | 11:35 PM
lSA
I like your cam suggestion! Duration and lift numbers that are close to the LQ9/late LQ4/LS1, BUT with a narrower LSA (3 degrees less). That should boost low RPM torque nicely; perfect for lower RPM aircraft duties.
