Oil pan alignment?
I had read where oil pans have cracked bolting the bell housing on when the pan alignment is off, when I checked it seems to be off slightly. I did put the bell housing on and snugged the bolts ~ 10 ft lbs and it appears fine... I'm just paranoid I guess???
Checked with the machine shop who said that where the bell housing bolts on the passenger side is not close to the area in question and you could not bolt the pan that far off and all is good.
It does seem fine... any insight here?
