Ls3 with 3.75" stroke
Did they ever put a 409 CID in a Pontiac? That would also be pretty cool. The pistons would be expensive, but it's just a 4" crank. The 6.0L iron block gives you lots of options.
I don't want to pee in your wheaties but I will a little, a Pontiac "428" is actually 426.6 cubic inches (4.12 x 4.12 x .7854 x 4 x 8= 426.61), the marketing guys decided that 428 was better because other companies had 426's & 427's.... If you want to get hung up on numbers that's fine but just remember that the factory did not. Build whatever you want and call it whatever you want that's what Pontiac and several other manufacturers did.
Then again, I've never been concerned with hitting a specific displacement. I am fine with my badge on the fender being a bit of a lie.
