Who has sleeved big CI NA setup?
It just so happens that I have a fresh RED Darton sleeved block in the shop. Towers are tapped for pipe plugs, fully de-burred and super nice. Rough bored to 4.148 for a 4.155 final hone, but can go out to 4.200 if your ready to party…. in case you guys are looking for a sleeved block. No wait.
The following users liked this post:
Che70velle (09-21-2023)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
If you do go with a stroker crank talk to the piston company and make sure they are aware of your sleeve length so they can design a piston with the correct taper. You would be surprised how much of the piston pops out the bottom of the sleeve on a 4.125 stroke on a short deck (about 3/8 of an inch or more).
The following 3 users liked this post by Double06:
The following 3 users liked this post by rkupon1:
With a 4.250 stroke, you’ll need the max length sleeve offered by Darton to make it work…ish. It just so happens that I have a fresh RED Darton sleeved block in the shop. Towers are tapped for pipe plugs, fully de-burred and super nice. Rough bored to 4.148 for a 4.155 final hone, but can go out to 4.200 if your ready to party…. in case you guys are looking for a sleeved block. No wait.
The following 2 users liked this post by C5_Pete:
Che70velle (09-25-2023), rkupon1 (09-26-2023)
I built a 4.185 x 4.125 darton wet sleeve ls2 block. It would twist the block and pop head gaskets, id have to use motor plates to stop it from doing that. Will try using it again when the motor goes in my ski boat. due to needing motor plates in the boat
I don’t doubt it Mick. Wet sleeving removes a lot of material. So much material that the block flexing caused the sleeves to move, which caused countless internal water leaks, along with the decks binding…which popped head gaskets. I’ve even seen cracked oil pans in wet sleeved builds. Dry sleeving is much, much stronger.
Che70velle (09-26-2023)
If the sleeves aren't long enough for long term reliability, you may save now, but spend more in the long term. Also, there are 4.100" stroke cranks out there that are "supposed" to be better for oil consumption. Scoggin Dickey sells them, Callies 4.100" stroke. YMMV..... ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I’m going with a 454 DART 31867112 block that has extended .375 barrels for full capture. Sure, it will likely only bring 620~650 hp +/- but I’m more interested in low rev., and massive torque across the band. I’ll likely never see more than 5000~. For my style of driving, that’s plenty of tour-mod cruising. 🤷♂️
