Ported LS3 Heads (specific) thoughts needed ASAP
I have an LS3 engine on order for install this week. Questioning, if these heads which are in stock are worth it to pair with a good size 233/253 .646/.637 112 LSA cam.
They appear to be stock casting 823 or L92 with PRC port work. The other option would possibly be GMPP CNC heads with .660 Springs.
LS3 and L92 CNC Ported Heads, PRC - Hawks Third Generation (hawksmotorsports.com)
I have to order today, to get to the shop on time.
I had it previously in my 1st motor(LS3).
I did contemplate a smaller exhaust split, but power would be down a bit. After the loss of my LS7. I need at least heads/cam as it will be quite a dropoff.
I like the rowdiness..
I'm tapped out. Going so far beyond what is reasonable after losing 20k in mods LS7 since last aug. Then sourcing and now swapping a LS3.
I got a set of Wilkes performance ported castings to pair with the SS3 cam. While it will make decent peak, it is going to feel gutless vs the LS7 setup.😮💨.
I got a corvette salvage LS3 complete. Was advertised as 38k and selller had an in car running clip sounded nice.
Engine arrived at the installers and he pulled out a comp cam. Says it has dual springs and oil pump installed. None of that was disclosed. (They typically do).
He is checking the rings on a piston tomorrow..
