Casting Numbers Help
Old Aug 29, 2023 | 04:31 PM
beau cooper's Avatar
Default Casting Numbers Help
I have a block that has the casting numbers 12567392. I was told it was a 4.8 but its been through mutiply owners and i dont know if thats true. When ever i look up the numbers it says its a 5.3/325. I took the pcm to get tuned and when i got it back the guy said "stand alone 5.3 tune with a 4l60." did he just tune it wrong or do i have a 5.3?
Old Aug 29, 2023 | 05:11 PM
Tommy42088's Avatar
If that's the matching ecu your tuner should of been able to determine if it was a 5.3 by your vin number also you should have another number on the driver's rear of the engine
Old Aug 29, 2023 | 05:22 PM
The 4.8 and 5.3 use the same casting as the only difference is the shorter stroke crank in the 4.8.
No differences in the block.
Old Aug 29, 2023 | 05:39 PM
Tommy42088's Avatar
he should still be able to tell from the vin though correct? if he has the matching ecu why couldnt his tuner pull it in his tune file?
Old Aug 29, 2023 | 06:11 PM
If he has the VIN for the block's original home he'll know the displacement.
