Ls3 crank question
I’m assuming is the exact same ls3 in a 2010 corvette. Doing a stock rebuild on either block as I have 2. I’m replacing the crank with a kit from my local part supplier and they have 2 different part numbers for the crank shaft kit between Camaro and corvette ? What could be different, they have the shafts listed as using the same cores, is something different internally I’m missing?
