CAM and Valve Springs Question
Option 1: Stock LS6 springs (Seat Pressure 90, Open Pressure 265, Install Height 1.800", Open Height [1.800-[b].466 = 1.334], 375 lb/in springs, cost $70-$100 each)
Option 2: Trickflow springs Part Number: TFS-16306 (Seat Pressure 108 [estimated], Open Pressure 318, Install Height 1.800", Open Height [1.800-.[b]466 = 1.334], 450 lb/in springs, cost $150 each )
Part of the rational for Option 2 is better seat pressure and more stable valve train.
Does this make sense, am I clueless in my analysis? Is there an option 3 that is better?
Rick
They are plenty stable for that cam. Keep in mind their normal application is in C5 Corvettes with a 400+ HP engine. No sense spending money on anything different
Seeing it typed that way is REALLY annoying, it's as though you are SHOUTING or even SCREAMING the word at us.That said, I agree with G Atsma, the LS6 springs are "adequate" for a stock LM7 cam. Personally, over the years though, I've found that you can NEVER go wrong with upgrading the springs, to a point. I have PAC 1218 springs in my stock LM7 ATM. Seat pressure is what's important; open pressure not as much. "Valve float" is almost always a function of the valves bouncing off the seat as they close, not "valve toss" where they launch into space at the top of the cam lobe profile. Especially not with a stock cam. Although, for an aircraft, it could be argued that some very mild double spring might be better than any of those, as it gives a backup in case one breaks.
Further info.. My Option 2 Is a double spring and I had thought/hoped it provided a level of redundancy. So I it looks like a better choice given my application. It's not a huge increase in spring pressure so I am not increasing wear and generating tons of heat. But better seat pressure to minimize/mitigate valve float which is what I was hoping for.
Option 2: ption 2: Trickflow springs Part Number: TFS-16306 (Seat Pressure 108 [estimated], Open Pressure 318, Install Height 1.800", Open Height [1.800-.[b]466 = 1.334], 450 lb/in springs, cost $150 each )
Thanks for the feedback!
I don't think you'll be gaining anything in regards to redundancy going to a dual spring, either. It's not like the inner spring is going to keep things together long enough to get to the nearest airport if the outer spring breaks.
...... Trending Topics
A redundancy factor weighs BIG in an aircraft situation.
If he can find dual springs with equivalent total spring forces to the LS2/3 beehives, it would be ideal.
Turns out some of the early AFR 225 heads installed height had been set up about .080"-.100" too short!! Springs were REV, but probably not their fault......Last edited by grinder11; Sep 28, 2023 at 08:42 AM.
We wouldn't sell to an aftermarket aircraft engine manufacturer due to the FAA requiring a "guarantee" on valve springs. That is something that 99.99% of the VS wire out there cannot do. The one (only one that I am aware of) that can, cost an insane amount of money, and i believe they even leave a fudge factor in their specifications for inclusions.
TurboBuick6: The springs I was thinking of using are Trick Flow® by PAC Racing Dual Valve Springs TFS-16306. My max camshaft lift is 0.466. Heads are stock 799/243 heads with 1.7 ratio rockers, to my knowledge no trunnion upgrade. Below is some information I gathered on 4 different valve springs.. I also found the PAC-1904 as a possible candidate.
The 4 springs outlined below are: PAC-1204X or TFS16306 or PAC-1904 or Stock GM springs (19420455)
- All are Standard Dual springs except the stock that is beehive/single. The engine currently has standard springs.
- All have an OD of 1.290 except TFS16306 @ 1.275. The springs currently in the engine are 1.320. Is this an issue?
- ID of Inner springs are .694/.675/.694/unknown.
- Seat Pressure is 145/150/150/90. It is my understanding that the rockers stock rockers can handle 175 lbs of seat load and 450 lbs of open load (OnAllCylinders.com)
- Spring rates are 369/450/370/375
- Open loads were calculated at .466 to be 317/356/322/265.
One other question.... Do I need to lap the valves? The engine is new, never run.
Rick
- All have an OD of 1.290 except TFS16306 @ 1.275. The springs currently in the engine are 1.320. Is this an issue? No, not an issue
- Seat Pressure is 145/150/150/90. It is my understanding that the rockers stock rockers can handle 175 lbs of seat load and 450 lbs of open load (OnAllCylinders.com) Yes, more than that IMO
If you go with a dual spring, you will need to change the locator, seal and retainer. You can re-use the locks. The 1904 is a great spring and is based off the 1204X. The difference is the 1204X was manufactured for dedicated racing, so it does have a little processing advantage over the 1904, however, either is a good choice. Even though the TFS springs are great, the PAC branded options are going to be a better option for you application in an airplane.
Rick
Agree on can't be too careful. I've seen some airboats with old Continental aircraft motors that use twin distributors. Would imagine the Lycomings are the same.... The rockers shouldn't really care too much about seat pressure; really, only the max they are subjected to, which would be at full open, would be an issue.
