12.0:1 ls3
The remainder of combo will be ls3 style head, milled with a .040-.045 gasket to achieve compression goals (dependent on the how much piston is in/out of hole. Cam is still undecided but this will be in a 96 c1500 single cab truck. 6L80/90 trans and 4000 minimum stall, possibly as high as 4500-4600 from Circle D if the combo needs it. E85 fuel. Gen 4 truck intake.
Truck will be primarily street driven. Maybe a track visit here and there. Looking for a stout truck that’ll be fun to drive on weekends.
While I’m here, I don’t really want to send the heads out for CNC work or port work. I’d like to keep costs down where I can currently and can do so later. But, with compression where I want to be, would I benefit from massaging the bowls, valve job, or anything from hand porting to help keep this combo happy?
We just put a very baby LG Motorsports executive cam in a new GM crate LS3 (10.7:1 compression) which has basically a stock idle with hint of something bigger and it made 456rwhp/446rwtq with a ported/rod modded LS3 intake, stock DBW TB and Sikky e36 mid length swap headers into a nice dual 2.5" exhaust on 91 octane using LSA/LS9 injectors and T56 Magnum with heavy McLeod steel flywheel/RXT clutch. Dumping in winter blend e85 which got it up to e58 mixture it made 470rwhp/457rwtq. In summer when the e85 content is higher I'm sure more power can be made. It was making over 330rwtq at 1500 basically and peaked at 6000rpm which is exactly what it is described as.
on the flip side I've used this same cam in a fully built 6.2 with MAST LS3 heads, stock LS3 intake/TB, Precision 88mm turbo and made 1060rwhp on 14psi with perfect street manners and a hint of non stock idle. On 22psi the car was a maniac (1450hp rated turbo) and made power well past 7000rpm.
I want to build something a little more on the aggressive side. I would like to rev to ~7-7200 with a setup like this. Peak torque in mid 4K range. Between a good matched converter, ~4.10-4.30 gear, and 6L trans gearing I believe I can still get by with missing a tad low end of power. Only reason I’m skimping a 416 project is this is a starting from scratch deal and don’t want to go that route until I’m bored with the power here.
Side note, it is interesting to still see a good gain on E with that setup given the compression and setup you described. E85 is everywhere for me so it’s a no brainer. truthfully, I’m not against running an even higher compression but still undecided. I do want to be minimum 12.0:1 though.
Quench is ultra important at 12:1 on pump gas. Get it down to .035, which is safe. I wouldn’t try any less for a street build. Tony Mamo tried .028 and it failed. Production tolerances come into play at that level, meaning if you have one rod out of a set that’s .001 longer, center to center length, for example, then you’ve got problems. Pin heights of pistons, rod journal heights on the cranks stroke not exactly perfect…That’s why I don’t like to go less than .035 quench, but .035 works to achieve what your after and that’s controlling the flame front as much as possible. If you come out at .033, I wouldn’t tear it all back apart to look for a .002 gain…just be aware that it’s ultra-tight while your revving to 7k+…
Tune will need to be great, not just good enough. You’ll want to use 93 pump from newer, clean stations, to avoid old, or even cheaper grades of 93. If you don’t mind the E85 route, then by all means, your super safe.
Don’t adjust your compression with headgaskets. It’s a bad practice. Use the headgasket to adjust quench only, and adjust the static compression with chamber volume and piston dome design. You’ll want valve reliefs that are deep but not crazy deep. It will require you mocking it all up a couple times to get it right and you MUst use the right measuring tools to find your out-of-hole numbers. A deck bridge with dual dial indicators is mandatory to find that number. Rock the piston at true TDC with the two indicators in the correct 12 o’clock-6 oclock position to find that number. You have to do this to all 8 holes to correctly evaluate your deck height and order the correct headgaskets. There is no guessing, based off of another build. Every build is different.
At the end of the day here, your engine doesn’t know or care what the static compression really is. Dynamic compression is what matters and is comprised by the valve events of the camshaft. Dynamic compression is what cylinder pressure is based off of and the static compression is simply a tuning aid at the end of the day. It’s all a fairly involved process that requires you choosing the right piston design, cutting the heads to the correct chamber volume, working with the camshaft company to get the valve events perfect, and setting up quench as tight as possible without letting the piston actually touch the head at high rpm. Then you have to rely on a tuner to get this optimized with fuel VE and not to put toooo much ignition timing in it.
I like to say to guys that are looking for max-effort stuff…”you have to build the engine first before you can actually build the engine at final assembly”.
I will chat it over with machine shop when I drop off the block and see what they suggest on a combo like this.
236/250 Duration @ .050''
111 LSA, 108 ICL (111+3)
.629''/.612'' Lift with 1.7
What do you guys think? Leaning towards a 4l80e possibly. Same stall range around 4500-5000. Definitely seems like a good sized cam with 21° overlap. I like it. Would this cam tap out around 7K or possibly higher?
If Cam-Motion recommended that cam for that rpm range, then I'm sure it will spin 7k or more. Just make sure you get the right springs for that cam and rpm.
Going to stick with the truck style manifold for this one. Hoping to have a little more broad torque curve. Would you say the torque on that one fell off a little early due to the vic intake?
cammotion and some 4.11’s. Truck manifold to maintain a little more power under curve as I’m fine giving up a little extra RPM/power up top if truck manifold has those type of characteristics over a ls3 mani.
