CNC heads clarification
Also, on the same heads, in the combustion chamber the area between the valves varys. One head in particular. One end is tight, the other end is a shoulder of 3/16 inch. ?
Looking to the experience of you all for clarity.
My background, playing with hp on a small scale for years. The last five years I dove right in! I have 30k plus in LS engines and parts on the shelf!
How about the shoulder between the valves? Seems to me something isn't in line?
As said, just put thread sealer on the bolts. Use the Permatex/Loctite "automotive thread sealant with PTFE"; NOT any kind of RTV. Gasoline will dissolve silicone.
You can add a washer under the bolt heads to keep them from protruding into the ports. You can also Heli-Coil the threads, which makes them MUCH more robust than just the aluminum by itself is.
As far as the variation in the space between valves, yes of course, that's pretty sloppy. Typical factory machine work. OTOH, THIMK for a minute about what you'd have to do to change it. You'd have to replace the guides to re-orient the valves, remove the existing seats, cut in new counterbores for them, and install new seats, which most likely would have to be larger than the OE. At some point, all that machine work gets PROHIBITIVELY expensive; i.e. not worth it. Since those look to be a "Stage 1" kind of port job, not what could be considered "max effort" or whatever, part of what you're NOT paying for in those, is that much machine work.
Q: How can you tell a used car seller is lying?
A: His lips are moving
Q: How can you tell a used car seller is stabbing you in the back?
A: He's smiling
And so on...
