Pushrod length help
Old Feb 6, 2024 | 08:59 PM
65LSXNOVA's Avatar
Default Pushrod length help
Does this sound correct?
ls3 block decked
tfs milled .060
​​​​tsp cam .625 lift
Felpro .041 head gasket
Morel 5290 lifters
Stock rockers
Started with 7.350 pushrod
Cam on base circle
1 full turn on intake
7/8 turn on exhaust
I then used my pushrod length checker and was getting 9.75 turns for zero lash. Comes out to...
​​​​​to 9.75 turns = .4875 + 6.8 total of 7.2875
then add lifter preload of say .040-.050
put me at a total length of 7.327 to 7.337
Should I go with 7.325 or stay with 7.350??
Old Feb 6, 2024 | 09:11 PM
I personally like to set up my hydraulic builds at the deeper end of the preload spectrum. It makes for a quieter lifter in my experience. Also remember your dealing with aluminum block/heads here, so thermal expansion of .010 is normal at temp…which adds to the value of setting up preload at the deepest side of recommended preload.
Old Feb 6, 2024 | 09:17 PM
65LSXNOVA's Avatar
I think these lifters have .140 travel on the plunger. Looks like the recommended preload of .050 + .010 for heat expansion and 7.287= 7.347
7.350 sounds right then unless your talking about running more preload than .050??
Old Feb 7, 2024 | 05:15 AM
Dbunke's Avatar
I Milled my 823 heads .050 with the same .041 felpro gaskets. I ended up with 7.375 on intake and 7.350 on exhaust. I think your in the ballpark depending on lifter preload . I was shooting for .075 preload.
Old Feb 9, 2024 | 12:49 AM
jayyyw's Avatar
Just keep in mind, if you order off the shelf, they are most likely going to be .012"-.015" longer than what they are advertised as. If you need the exact length or close to it, I suggest ordering from Manton. This last set I got from them was within .003".
