Custom pistons - what company
Old Apr 12, 2024 | 12:10 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Custom pistons - what company
Looking for inputs on best custom pistons, without having to spend $200 per piston.
4.155" bore, 4" stroke, N/A 12:1 compression. Piston oil squirters.
Old Apr 12, 2024 | 08:16 PM
Moving this to Gen4…
Old Apr 12, 2024 | 09:12 PM
TrendSetter's Avatar
I really like my diamond pistons I bought for my ecotec but they were about $200 each with pins and rings.
if you can’t afford that you need to stick with sbe.
Old Apr 13, 2024 | 07:51 AM
Double06's Avatar
Diamond are pretty good just got a set for my BBC. I had some custom Wisecos also for my LS motor.
Old Apr 13, 2024 | 08:28 AM
Last 1's Avatar
call CNC Motorsport they got me a set of Custom order 4.170 bore(410 grams )JE FSR 5 cc = 12.5 to 1 for NA motor (my RHS block already bore 4.165 didn’t want to bore it no bigger than I had to)
I paid around 970.00+200 for the upgraded wrist pins
I’m sure they can take care of you,and tell you what pistons will work for your oil squirters
Old Apr 13, 2024 | 11:13 AM
MuhThugga's Avatar
RaceTec makes nice pistons. Their AutoTec line should be within your budget.
Old Apr 13, 2024 | 07:50 PM
FCar2000TA's Avatar
Veteran: Air Force
$200 max is for the piston alone. Not including rings and pins
Old Apr 14, 2024 | 03:19 PM
FCar2000TA's Avatar
Veteran: Air Force
My bad.
