Ls7 crank in ls2 w/ wet sump?
I have a guy selling an ls7 Crank near me for a good price. I've seen stuff floating around (but nothing super concrete) about using an ls7 with a wet sump. Does anyone have any solid info on what's needed to make it work?
Thanks!
Thanks!
The following users liked this post:
pannetron (05-02-2024)
Yes, unless you are planning to run the LS7 rods, I would look for an aftermarket wet sump crank. Balancing the stock LS7 crank with steel rods will likely cost you upwards of $800, alone. That, with the cost of the crank itself, you could get a new aftermarket K1 or Callies for not much more.
