New Summit Max Efi intakes.
Old May 11, 2024 | 02:06 PM
Summitracing's Avatar
LS1Tech Sponsor
Default New Summit Max Efi intakes.
They’ve been in development for a while but the new Summit Max Efi Ls intakes are out! The taller profile ones have longer runners and more plenum volume (9.7L) than typical sheet metal Ls intakes. Mid and short profile, Rectangle and Cathedral, Black or polished, 92 or 102mm Tb versions. Better mixture distribution and performed well in our testing. $499 (with fuel rails) introductory price too!
if you go into the photos, check out the 360 view and you can see the runners and bells extending up into the plenum rather than cut-off at the surface. The plenum material is thicker than what’s commonly used so good for boost!
__________________
800-230-3030
www.SummitRacing.com
Old May 11, 2024 | 04:30 PM
old motorhead's Avatar
Sexy
Old May 12, 2024 | 07:26 AM
grubinski's Avatar
What is the height of the low profile cathedral port version vs a cathedral port FAST 102?
Any dyno results?
Old May 18, 2024 | 10:28 AM
LSleeper1500's Avatar
I see they advertise 8000 RPM. What are your thoughts on this intake for a 416, 242/258 cam, FED Stage 2 LS3 heads shooting for 7000-7500 RPM? Currently looking at the FAST HR or Holley Hi ram
Old May 23, 2024 | 12:04 PM
LS1Tech Sponsor
Any dyno results?
Check out the measurements for the low-profile manifold over on this thread. We don't have dyno results yet. We do plan on getting these new manifolds in for some dyno testing. Time will tell and we'll be sure to post the results here on LS1Tech when we do.
Yes, the Low-Profile manifolds have a 4,000-8,000 RPM operating range. The tall profile intakes have a 4,500-8,500 RPM operating range. Either are available in a Satin or Black finish. See the thread linked above for measurements on both profiles. If you have the room for the tall profile intake that's what we'd go with for a healthy engine like yours.
__________________
800-230-3030
Old Aug 22, 2024 | 12:14 PM
maunder's Avatar
These make it to dyno yet?
Old Aug 22, 2024 | 01:52 PM
LS1Tech Sponsor
Unfortunately, not yet. We had a guy on Boosted LSX using one of the Max EFI intakes pushing over 40PSI and it moved the power up and to the right!
Also, we've sent two for third-party testing and are awaiting feedback to share with the community!
__________________
800-230-3030
Old Aug 22, 2024 | 05:56 PM
68Formula's Avatar
Missed this before. That's a nice piece. Seems robust enough that it won't flex like a lung under WOT like some of the cheap sheet metal intakes.
