New Summit Racing Max Efi intake manifolds.
Old May 11, 2024 | 02:04 PM
Summitracing's Avatar
LS1Tech Sponsor
Default New Summit Racing Max Efi intake manifolds.
They’ve been in development for a while but the new Summit Max Efi Ls intakes are out! The taller profile ones have longer runners and more plenum volume (9.7L) than typical sheet metal Ls intakes. Mid and short profile, Rectangle and Cathedral, Black or polished, 92 or 102mm Tb versions. Better mixture distribution and performed well in our testing. $499 (with fuel rails) introductory price too!
if you go into the photos, check out the 360 view and you can see the runners and bells extending up into the plenum rather than cut-off at the surface. The plenum material is thicker than what’s commonly used so good for boost!
__________________
800-230-3030
www.SummitRacing.com
Old May 11, 2024 | 02:53 PM
sjsingle1's Avatar
any dyno tests on this bad boy ?
Old May 11, 2024 | 04:26 PM
LS1Tech Sponsor
Generally we don’t compete head to head with our vendors (nearly everyone) so they usually end up in the hands of a third-party like Richard Holdener. Let us see what we could give as a comparison.
__________________
800-230-3030
Old May 11, 2024 | 05:52 PM
You better believe Richie will want to dyno this baby forthwith!!
Old May 11, 2024 | 10:44 PM
Utinator's Avatar
I bet the power curve will look like the FAST with the mid-length runners. I wonder if this will fit under my hood.
Old May 13, 2024 | 10:41 AM
LS1Tech Sponsor
It will be curious to see. We have a fourth Gen Camaro and we're probably going to swap intakes on it to verify whether the low (and possibly the high) profile versions would work,
__________________
800-230-3030
Old May 13, 2024 | 03:34 PM
LS1 TJ's Avatar
Would it be possible to get pics detailing the height difference between the new Summit intake next to the LS6 and LS3 intakes? Maybe just put them on a table and take few pics with a tape measure.
Old May 13, 2024 | 06:07 PM
LS1Tech Sponsor
On it. The physical height at its peak is 7.480 for the low and 8.270 for the taller one, but it doesn’t really describe the slope down that people will be looking at to clear cowl’s. We’ll pull them and get you folks some good data.
__________________
800-230-3030
Old May 15, 2024 | 11:53 AM
Falcoms's Avatar
Out of curiosity, do you have any dimension drawings showing the centerline of the throttle body bore? I'm curious to see which intake will work best on my race car to clear the front support brace. Also, it looks like there's a MAP sensor port on the back, is that correct?
Also, do you know if anyone from Summit Racing will be at Mid-Ohio for the Hoosier Super Tour race this weekend that I might be able to talk to about this more in depth? I know I need to get a shorter runner intake manifold for my setup, and this looks like it should work well for my application.
Old May 16, 2024 | 11:09 PM
Abs's Avatar
Abs
I would love to see how this compared to an ls6 power wise.
Old May 18, 2024 | 03:55 PM
DualQuadDave's Avatar
What is the runner length on the long one?
Old May 18, 2024 | 04:45 PM
Mr. Black's Avatar
Man, this is SO DAMN TEMPTING.
Don't manifolds of this general shape have no bottom end power N/A? I know it's not good to make generalizations or assumptions lol.
I'm happy with the performance of the NNBS intake but holy ***** it is FUGLY!
How long is the introductory price so I know how long I have to be tempted for?
Old May 18, 2024 | 04:51 PM
Mr. Black's Avatar
Taken from the Summit website overview.
Basic Operating RPM Range:
4,500-8,500
It's probably not the best idea for my usage.
Old May 19, 2024 | 06:22 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Those fugly truck manifolds can be smoothed and painted to look pretty decent. No need to be stuck with a glob of black plastic with **** sticking out all over it.
Old May 22, 2024 | 01:13 PM
LS1Tech Sponsor
First up is the Tall Boy:
- The top peak of the throttle body flange is 8.5”
- 3* plenum taper to 7" over top of the rear-most runner before heavy radius down to 6.5" at the back.
- The 2.635" x 1.018" runner at the intake flange (not including additional in the injector boss area) is about 2.7" CSA. The runner is 5.5” long and measures 2.150" I.D. below the bell which equals 3.63" CSA to give you an idea of runner taper.
-12.85 lbs. without fuel rails so lighter than cast manifolds by a large margin.
-Throttle body face extends 4.625 in. forward of front-most driver’s side intake manifold bolt for reference.
-Fuel Rail I.D. .702 for M1 if required.
__________________
800-230-3030
Old May 22, 2024 | 01:57 PM
LS1Tech Sponsor
Next up is the Lo-boy:
- The top peak of the throttle body flange is 7”.
- 1.8* plenum taper to 6” over top of the rear-most runner before heavy radius down to 5.25" at the back.
- The runner length is nearly the same as the Tall-boy at 5.25".
- The difference is the whole plenum is dropped over the runners. The underside of the plenum is only 1.500" above the valley vs. 2.900" above the valley with the Tall-boy. The runner protrusion into the plenum with the Lo-boy is 2.250" vs. 1.500" with the Tall-boy. This means that torque with the Lo-boy isn’t going to be *that* much down on the Tall-boy. Also 12.85 lbs. without fuel rails for a lot less weight than cast.
__________________
800-230-3030
Old Aug 22, 2024 | 06:18 AM
maunder's Avatar
Any one test this out yet? Curious how they compare to other intakes. Was going to go Hi-Ram but am now considering this option.
Old Aug 22, 2024 | 01:51 PM
LS1Tech Sponsor
Unfortunately, not yet. We had a guy on Boosted LSX using one of the Max EFI intakes pushing over 40PSI and it moved the power up and to the right!
Also, we've sent two for third-party testing and are awaiting feedback to share with the community!
__________________
800-230-3030
Old Aug 25, 2024 | 05:50 PM
Utinator's Avatar
Did you send some to Richard Holdener? He already tested all the other intakes on the market. He would have the data needed to make a good comparison.
Old Aug 26, 2024 | 05:56 PM
Ananta1369's Avatar
Do it! I'll wait...
