exhaust flow impact on cam specs
I want to stay quiet for street driving without getting too much attention. I have 1 3/4" primary, 3" collector long tube headers, off road pipes and a 2.5 magnaflow catback with their quieter mufflers.
I'm also making around 4 digit power estimated at the crank shaft. It doesn't seem like most dyno comparisons show a huge difference in power by going to larger headers or exhaust. Looking ahead to even more power on a new engine combo how much can I compensate with cam specs for the restrictive exhaust at over 1000 rwhp?
https://m.youtube.com/watch?v=_LIJTbAa4K8
are you wanting an answer to your question, or are you just showing off your car? just wondering because this looks like its taking a turn.....lol
I already have a 232/248 custom cam for my current combo. I’m not a smart man so I should have explained better.
I’m considering building a 388 putting more of my budget into the bottom end with an aftermarket aluminum block while running cheaper heads and my current exhaust. I would also be going with an F1x over my current f1a-94.
Basically with this exhaust and less than ideal heads initially shooting for 1200 plus rwhp is it possible to compensate for those factors with cam specs and how much would I really be giving up on a combo like that.
Compression would be 10.5 ish to 1 static and fuel is e85 plus meth injection.
man come on. You ain’t no dummy so don’t say you aren’t smart lol.
I felt like my example was relevant. The first combo ran far better with a large split on the exhaust. Thinking going to a larger cam but a closer split with better heads should have made the car faster but it didn’t. That big motor with the small exhaust really liked the large duration split. If I had a supercharged motor I’d be running large split like that. The cam you have now seems pretty ideal on the split. I think in your situation you should be looking at doing really quiet exhaust setup with some cutouts or bypass mufflers for racing. That’s why I built my whole exhaust and fabricated my muffler. Quiet for driving and bypass the muffler when I want to. It makes 2-3 more psi boost when the bypass is open.
