LS7 guide wear after "fix".....
But the head will be off tomorrow and then I'll go over to the drivers side to unbolt the headers from drivers side head and remove the 15 nuts and washers over there. I'll pull that head tomorrow, too. Just to be clear, I'm not complaining about being 70. It's just obvious you have to make a few adjustments to your work schedule. Wife has a little sign by her garden. It says old Irish proverb "Do not regret growing old-Many are denied the privilege!!"
) towards the intake side. This had the effect of an impact wrench, but instead of rotational forces, they were horizontal. Check out the attached photos of the Ti retainer. It actually has the spiral helix of the valvespring worn into it!!!!!
Anyway, I finally got the drivers side head off. It was ready to pull at 1:30. But.....I forgot what an absolute PAIN IN THE *** removing the alternator bracket is. Had to get the power steering fluid out of the resrvoir, so I used a turkey baster, which I remember doing before. Then removed the hose from the reservoir and where it attaches to the pump inlet. Had to do that so I could access the last bolt that held the bracket to the head. Draining the reservoir best I could and removing the 4 bolts holding the bracket on took me 2 damn hours. Wish the engineers who designed this mess worked on this stuff!
Had to give it up for today. Back said NO MORE!! But both heads are on the bench now, and all springs, retainers, and the valves will be out tomorrow. Will post results and pics......
The other 14 valves all smoothly fell out of the heads after they cleared the guide seals.
LS7 rocker mounts? Pics are marginal, but if you zoom in you can see some are exhibiting some kinda strange marks on the scallops. When I tighten the rockers on each mount, I use one hand to wiggle the trunnion in a slight twisting motion, using my thumb and index finger to help "nest" the trunnion in the stand as I tighten the mounting bolt. Do this same thing on all 16 pedestals. Not all the stands exhibit these weird patterns. What say you???....
In my time spent in the industry, with the R&D work we did for Cup teams as well as other professional Motorsports teams, we did a lot of internal video work. We studied windage under “glassed” valvecovers (along with other areas of the engine) with dry sump oiling systems, to determine what the internal atmosphere looked like in the top end, at 8k+ rpm. The footage was very high quality for the 90’s and we slowed it down to very low frame rates, so slow in fact that we could see rocker flex, rocker shaft (Jesel) flex, valvespring disorientation, etc.
To go slightly off-topic here in an effort to clear up some past discussions on the subject of the rocker wheel sliding across the valve tip…it does NOT slide. The wheel rolls in both directions accurately and precisely as long as lash is kept in check by the valvesprings doing a good job. I’ve seen hours of live footage up close and personal and I’m tired of seeing bad info out there…rant over.
I have no doubt that as those LS7 pedestals flex at very high speed, there is also rocker bolt stretch and the trunnion is likely moving around some in the saddle. To add insult to injury here, this also introduces harmonics into a valvetrain that’s already being scrutinized. Any increase in spring rate along with the associated increase in RPM will only make this worse. And for the guys that have had their LS7 castings ported, which removes material directly under the rocker pedestal, this issue at hand is made much worse.
At this point, I'd go in another direction. What's the definition of insanity? I have no experience with LS7 stuff. I will say that my LS3 build has over 50K miles on it. The heads I sent to Tx Speed for porting, milling, and valve job had 10K miles on them. I don't believe Tx Speed touched the valve guides. The cam is a .620 lift Cam Motion custom grind. It's had two set of stock rocker arms along with two sets of BTR platinum dual valve springs. Both changed out at the 30K mile mark. The old rockers looked and felt perfect at the swap. While not LS7 power, 500 at the wheels moves a 3200# Vette around nicely.
I understand that going to an LS3 top end will cost you some power. If you do decide to go the LS3 route, I have an LS3 intake manifold laying around if you need it.
