Which "stroker" cam?
Any recommendations and opinions are appreciated!
Cam Motion Hot Street Stroker LS Camshaft (236/248-112+4) for "Single Plane" Rectangle Port
or
Hot Street Stroker LS Camshaft (239/247-113+3) for Rectangle Port or Street King Stroker LS Camshaft (242/254-110+4) for "Single Plane" Rectangle Port
or
https://cammotion.com/camshafts/hot-street-stroker-ls-camshaft-236-248-112-4-for-single-plane-rectangle-port/
BTR 400+ NA V2 236/25X, .636"/.636", 114 LSA, INTAKE LOBE LIFT @ TDC: 0.06514
https://briantooleyracing.com/btr-400-na-camshaft-v2.html
Smeding Performance Rectangle Port R4: .624”/.615” Valve Lift w/ 1.7 Rocker 245/256 Duration @ .050” 113LSA + 5* Advance
https://smedingperformance.com/products/rectangle-port?variant=40534849683514
Tick Performance Square Port Stroker Stage 2 Camshaft
241/254 | .630”/.617” | LSA113+3
https://www.tickperformance.com/tick-performance-square-port-stroker-cam-stage-2/
If this is an efi car and you want it to drive well, I would go with something like the cam motion hot street or torquey stroker cam. It will drive very well, no surging, pull nice to 6500 and peak torque around 4500ish. Probably 470-490rwhp ish.
If you want to run a number I'd go bigger than what's listed here. Likely in the high 24x/26x 110 range. It would make peak torque around 5200-5500ish and should pull to 7500. Likely closer to 520 wheel HP unlocked.
For reference. I currently have a 408 with trickflow ls3 heads. Fast mid runners ported, 246/266 111 .700 llsr cam and 12 to 1 scr. Made 520 unlocked through slicks and and 9" rear. Probably around 670-700 crank. It does have some minor low speed idle surge, very minor, I wouldn't want to daily it but for a weekend car it's great.
similar goals. Weekend cruiser/hot rod. Mine will be 416 at 12.0:1 comp, FED ported ls3 heads, holley hi ram in a 96 single cab. Roughly 4K lbs
