5.3 internals
Old Aug 14, 2024 | 11:29 AM
Colemanj9483's Avatar
Default 5.3 internals
If I take rods and pistons from one motor and put them on a different Crankshaft would I need to have the engine balanced? Engine has a 3stage cam
Old Aug 14, 2024 | 12:48 PM
Kfxguy's Avatar
it should be ok. Who would you get to do it?
Old Aug 14, 2024 | 01:20 PM
Myself
Old Aug 14, 2024 | 01:24 PM
Kfxguy's Avatar
Originally Posted by Colemanj9483
Myself
You have a balancing setup? If so, why not check it? Yea its a little involved setting it all up, but if you have the means, then do it. Or simply weight the old parts vs the new parts. 10 grams difference is acceptable.
You are not talking about weight matching, are you?
Old Aug 14, 2024 | 01:36 PM
I do not have a balance setup I was just wondering if it’s really necessary to have it balanced. It has a 3stage cam in it and I don’t plan on doing anything extra at this time. Just trying to take all the good parts from two engines and make one. Lol I’m on a budget but if it’s something necessary then I’ll have to wait on get that done.
Old Aug 14, 2024 | 02:09 PM
Kfxguy's Avatar
do you have the original rods and pistons that were on the crank you are wanting to put the other rods and pistons? If so, weigh them. They weigh close to the same, you are good. Btw, when I built my 5.3, I used H beam rods and forged pistons….my machinist said the weights were close enough I could have ran it without balancing.
Old Aug 14, 2024 | 02:45 PM
I have the original rods and pistons from engine 1 but they are badly damaged real bad
Engine 1
. Engine 2 have good rods and piston bad crankshaft. All parts are OEM originals. I just wanted a second opinion on swapping without needing balancing
