I'm putting a ls3 in a 69 Camaro and looking for a pretty aggressive cam to put in it and I'm looking at gpi's ss4nfc cam. I was also thinking about going ahead and get the heads CNC ported but im worried about clearance with this cam because they mill the heads to minimum to get them flat. Would getting the stock LS3 heads ported be worth the hassle? Figure i would do all i could once before the motor goes in. Anybody have clearance issues with this cam or does anybody have any other recommendations on another cam that makes the same power? Thanks
They don't have to mill the heads much at all to get them flat. Not sure where you're going with that. Also, they sink the valves in the heads when doing a valve job. That increases the PTV clearance all else being equal. I would get GPI's thoughts on this. Also, consider their ported and rod modded intake manifold for your build. You don't need a monster cam if the heads and intake manifold are really good. Bump the compression ratio up with a thinner head gasket and minimal head milling. Don't know what your power goals are, but my LS3 with CNC ported heads, GPI ported and rod modded intake mani, heads milled .010, .040 head gaskets, and a few other minor mods made 500 at the wheels with a baby cam. I'm thinking about putting something just like that in my '69 Camaro.
It's got a 406 gen 1 small block in it now. Needs a new carb or some type of fuel injection. Decisions decisions
A good running '69 Camaro is ****...
about 500 rwhp is what Im looking for. I have a LS2 with ported 799 and btr stage 4 cam in a 68 Camaro now and it went 11.1 @124 with a 6 speed in full street form minus bias ply slicks. If I could get the ls3 to make 500 rwhp I’d be happy.
Mine was done with an M6 manual trans in a C6 Vette. Cam is a 226/234 115+4 with .620 lift on both sides custom grind by Cam Motion. I was looking for the most I could get while retaining excellent street manners. With a 0 overlap cam, I knew the street manners would be good. The numbers were what they were.
The old 230/236 112+4 cam from Spinmonster is proven 500whp with supporting bolt ons. I have a new Summit 8710R1 I would sell, 230/242 113+4 .620/.600. That is a proven 489whp cam with good torque everywhere. Out powers some cams bigger than itself.
Pretty sure Spin's cam is a 230/234 114+2. Not sure on the lift.
You are correct, I was quoting from memory got it wrong a touch. It is 230/234 114+2, but if I did one of those I would add some overlap and narrow it a touch. It would only work better, imo.
