LS3 Based 427 Leaking Sleeve?
point is its not something to stress out about just yet. If it was my car, Id pickup a handful of coolant test strips, and some of those sealing pellets gm used to put in the aluminum caddys at the factory. Give those a try and the test strips will let you know the progress.
you’ll probably need to change the coolant too.
Steve is quite thorough, I would give him the initial benefit of doubt that it’s something else.
I’m sure Steve already told you, but you want to go back over your head bolts/studs,…back them off a touch and re-torque them one at a time in correct sequence…and let the engine heat cycle a few times afterward.
https://www.summitracing.com/parts/NAL-12378255
EDIT! I see you used Cometic gaskets. Probably a good idea to retorque. Especially if you've tried the tabs.....
