X3!......And people still wonder why some of us run dual springs when a single spring "could" meet the cams requirements. I realize GM used single spring, so not your choice. I once broke an outer spring. 300 miles on a fresh 427. Left a stop sign, only 1 mile from home, under light throttle. I was leaving for work at 4:45 A.M. At approximately 2,000 rpm as the 4L60E shifted to second gear, all of a sudden RAP, RAP, RAP, then no more noise. I shut it down. Saved the motor!!! I restarted the engine, and sounded fine. Drove it 1 mile back home (I know, I shouldn't have, but I got lucky!) with no more noises. Pulled a valve cover that afternoon, and found the outer spring in 3 pieces, with 2 of them lodged in the heads oil drain back holes!! Sorry to hear of your loss......
