LS7 700whp
Old Dec 26, 2024 | 12:07 PM
Dansic's Avatar
Default LS7 700whp
I have a lofty goal and I'd like to see what other people have put together to get close to it. I'm putting my LS7 back together after a lifter failure and I'm shooting for 700whp NA. I have 13:1 compression now, and MSD intake and a 253/268 @ .050 cam grind. I'm probably going to have IronMask port the MSD intake to his Maximus 112sr and work the heads to match. I'm running E85 through FIC 1000cc injectors. I'm told so far I might see around 670whp with this. Have any of you built a 700whp NA 427, and if so are you willing to share what you did? I havent assembled anything, so I can still make changes.
Old Dec 26, 2024 | 03:02 PM
Ls1Rx-7's Avatar
If you don’t have hood clearance issues and can fit a high ram I’d suggest going that route. The msd iron mask will get you close but I don’t think it can get past 700rwhp.
Old Dec 26, 2024 | 03:11 PM
Dansic's Avatar
I dont unfortunately. Its going in my 15 Z28. Im just looking to get as close as I can and still run on pump E85 without taking my hood off.
Old Dec 26, 2024 | 03:28 PM
Ls1Rx-7's Avatar
im in the same boat with my rx7 and plan on running the iron mask 112 on my 454. Beck makes a custom sheet metal manifold that’s close to the same height as the msd but other than that your limited.
Old Dec 26, 2024 | 03:33 PM
DarthV8r, who is a mod here, did 692 on pump 93 with an MMS MSD and MMS 265 heads a couple years ago. He’s running 12.5 compression. On E, he would be well over 700. You can get there, but the devil is in the details. I did the 440 shortblock for Darth and it was a very trick build. He does have a tick more cam than you also at a 256/270 if I remember right…
Old Dec 26, 2024 | 04:28 PM
Omega Doom's Avatar
I know RPM had one of their C6Z06s hit like 670rwhp on pump 93 with their B3 cam so im thinking if you go with like the CF PTR Hi-ram manifold 103mm Katech TB custom Cam Motion LLSR Cam and either AHP Arch Angel LS7 heads or the Frankestein versions and all the little supporting mods its very attainable there have been a few who have already done this and there is a C6 Z06 out of Texas GapGod i think he goes by on the internet that is close to 800hp not sure if thats rwhp or just HP though good luck though and remember tuning is always the key
Old Dec 26, 2024 | 05:57 PM
Double06's Avatar
Paging - Jayyyw. You are needed in the forum on floor 4.
Old Dec 26, 2024 | 06:23 PM
DualQuadDave's Avatar
The core of the recipes doing it are good enough heads, .750+ lift, get the headers and intake on point. More cubes is easier, but no matter what you need to rpm it to get there. I would look at a LS3 low ram intake and slap the LS7/LS3 adapters on it or epoxy it to match. The shorter runner will make it rpm which will get you the number. That being said, the MSD may be faster overall, especially in a Z, that thing isn't light. If you don't already have the short block done, go big👍.
 Michael S. Palmer
Old Dec 26, 2024 | 07:22 PM
jayyyw's Avatar
Cam duration AND lift.
I made 760whp with CID heads, 14.5 compression, 262/277 .800"/.800" 115LSA, Hi Ram, Pump E85, Stepped headers and 3.5" exhaust.
Old Dec 27, 2024 | 09:38 AM
I miss the NA of your car so much, lol. Merry Christmas to you and your family👍 Hope all is good.
Old Dec 27, 2024 | 03:54 PM
Ryans99ls1's Avatar
If you're on the factory ecu, it's gonna be tough to clip 700 being rpm and intake limited. You're gonna need compression (I'd be shooting for 14+) and cam lift (min .750") to get there and a wide open intake path.
Take a peak at my build thread, I'm sure you'll find similarities there to start with
Old Dec 27, 2024 | 07:39 PM
jayyyw's Avatar
I don't agree with that.
Old Dec 28, 2024 | 04:10 PM
Ls1Rx-7's Avatar
didn’t you lose power going to a Holley vs a stock tuned ecu? From what I remember it was substantial like 10-15rwhp. I think your thread is the absolute best source of info for a big cube high hp LS build on this forum.
Old Dec 28, 2024 | 06:20 PM
jayyyw's Avatar
I never tuned it on the stock computer. All my hi ram setups have peaked around 72-7300. You need a pretty huge cam to peak higher with 427+ cubic inches or a short runner intake.
Old Dec 29, 2024 | 06:09 PM
gnx7's Avatar
It only take money to make 700rwhp n/a Agreed with needing better heads (AllPro, MAST, Frankenstein, CID, etc). Then the last few ponies are all about perfecting the combo with better headers, slightly bigger cam, more compression etc.
Old Dec 29, 2024 | 07:49 PM
Ryans99ls1's Avatar
Tough was probably the wrong word, it's definitely doable. But I still don't like the factory ecu for a push beyond 700whp. You're getting into cam specs and intakes that want more rpm than it has to offer. Or you're just cutting off a part of your powerband.
Old Dec 29, 2024 | 09:36 PM
John B's Avatar
Moderator
The search tab is your friend lol....stock bottom end LS7 on the Factory E38 ECU here at 700+ NA....https://ls1tech.com/forums/dynamomet...-700-rwhp.html
Old Dec 29, 2024 | 09:51 PM
the_merv's Avatar
Veteran: Air Force
I was waiting for you to chime in on this John..
Old Dec 30, 2024 | 06:27 AM
Mickyinks's Avatar
Lax 454, Mamo tra heads + msd intake , e38 ecu , 700+rwhp
Old Dec 30, 2024 | 07:10 AM
02EBC5Z06's Avatar
As the others mentioned. The basic recipe falls down to very stable valvetrain. The heads need to be able to do what you want and then some (good flow and velocity in all lift measurements). The cam as @jayyyw stated is going to need to be more than the BTR 4 you were talking about using in your facebook post (at least from what I remember that is what you were looking to use, I may be wrong). Definitely give it as much lift and rpm a possible. Either a hi ram, Brentons MSD 112 setup will get there.
