LS7 700whp
Old Dec 30, 2024 | 09:58 AM
Dansic's Avatar
Originally Posted by 02EBC5Z06
As the others mentioned. The basic recipe falls down to very stable valvetrain. The heads need to be able to do what you want and then some (good flow and velocity in all lift measurements). The cam as @jayyyw stated is going to need to be more than the BTR 4 you were talking about using in your facebook post (at least from what I remember that is what you were looking to use, I may be wrong). Definitely give it as much lift and rpm a possible. Either a hi ram, Brentons MSD 112 setup will get there.
Im not using a BTR cam anymore. I have had a few companies give me custom grind for the goal, but none of them are much bigger than the BTR 4v2 really. Which is why I'm asking around. If I waited to put it together for a while, I could build with more cubes and compression but I need to stay within pump E85 capabilities.
Old Dec 30, 2024 | 10:01 AM
02EBC5Z06's Avatar
@jayyyw motor was around 14.5:1 on pump e85 with no issues.. My 408 is 14.5 as well and will be on pump corn. Hell, I should have actually ran a thinner gasket bringing my static up to 15:1 which would have gave me a bit better quench and I still would have ran it on pump e
Old Dec 30, 2024 | 10:02 AM
02EBC5Z06's Avatar
Like we also stated in your facebook thread, the aftermarket crank and rods won't make the power that a stock ti rod setup would, but if you focus on the top end a bit more, you will be just fine and can get your goal.
Old Dec 31, 2024 | 07:47 AM
Double06's Avatar
I think on the titanium rods you can make the weight up in other ways (the rods are about 150 grams lighter each than say an aftermarket steel rod 620 vs 470). The Callies crank I think on mine was 5 pounds (2500 grams) lighter than OEM (57 pounds vs 52). The OEM piston I think is like 480 grams whereas aftermarket is like low 400s. If a stick shift a light flywheel can help but that has its own drawbacks.
Old Dec 31, 2024 | 10:01 AM
02EBC5Z06's Avatar
Yeah, on my 408 I used a 15lb steel flywheel from Texas Drivetrain instead of the 28lb centerforce that was on it before with my RXT. Should help it rev up quicker.
Old Jan 1, 2025 | 08:14 PM
jayyyw's Avatar
HUC lobes are very stable and they can come with ~.720" lift on a 1.8 rocker. 26X/27X .720/.720 115LSA would get you there.
Old Jan 4, 2025 | 01:59 PM
gnx7's Avatar
I run the Mcleod alum flywheel 11lb on basically all my builds... definitely notice it over a factory iron flywheel. It drives just fine.
Old Jan 8, 2025 | 08:53 AM
logan2ss's Avatar
OP, I would go bigger on the cam specs for sure. My setup is bore limited but still should give some insight. I have a 258/268 @.050 cam with .675/.657 lift, limited by the rating of the Comp BSR shaft rockers. My engine is a 416 so is basically stock LS3 bore sizing with a small bore BR7 head. Compression is up there, 15:1 and the first dyno trip it made 642whp. This was before adding a velocity stack, 3.5 header collectors, and some other small changes that should give a few hp here or there. That was made on pump E85 as well. I would assume I might fall in that 660-670 range like someone had assumed you would be in. I say that would be a pretty good guess just based on my experience. If I were you I would put some more cam in it and some more compression, that should be able to get you knocking on the door of 700.
Old Jan 8, 2025 | 08:59 AM
grinder11's Avatar
I disagree that you can't make the same power a Ti rod setup would. You may have a quicker acceleration rate of the rotating assembly with the Ti rod setup, which could result in a lower E.T., but many tests thru the years have shown lighter weight rotating assemblies do NOT make more power. I know what you're saying, but there'll be no power increase......
Old Jan 9, 2025 | 12:17 PM
02EBC5Z06's Avatar
I am not saying that you cannot make the same power, but I have seen it time and time again where C6Z guys changed the factory crank, rods and pistons for aftermarket steel options and made less power on very similar setups that retained the titanium rods.
Old Jan 9, 2025 | 09:27 PM
Floorman279's Avatar
so this has been discussed a lot between me and a random tuner and a random builder. what the tuner cant fathom is how the ls7 rod which is 6.098 or 6.076 length whatever, so shorter than a 6.125 rod, and has shorter dwell time at tdc than an aftermarket rod/piston, somehow seems to always make more than the heavier aftermarket setup.
i also know someone who says heavier cranks make more power than the lightened ones.
anyway, a bit of thought has gone into my rods/pistons for my setup which at this rate will never be running. what i can say that somewhere is a 434 shortblock on the stands, has XXX pistons, XXX rings, a standard compstar CCW crank, but the cool thing is the lunati X beam steel rods. since we all agree lighter rods make more power in n/a, and i dont like the titanium coating, the builder wanted to try them. they come in somewhere around 550-560 grams i think, NA only, and rated at 8000 rpm. Since i am trying a short runner msd, i dont see myself going over that.
basically building this thing around the intake. this a c6z and i am 100% keeping the stock hood untouched. Im pretty sure i wont be happy with the short runner intake so that means my next and probably only option would be a btr trinity, then ill probably be shifting around 82-8300 rpm so slightly over the recommended rpm on the rods.
Old Jan 9, 2025 | 10:02 PM
  #32
spanks13's Avatar
I believe he tried both the modded MSD and the fully ported Trinity and the MSD won out.
https://ls1tech.com/forums/generatio...ls7-build.html
Old Jan 10, 2025 | 01:01 AM
  #33
jayyyw's Avatar
I've seen them lose power with even only just aftermarket pistons. Everything else the same, they lose roughly 20whp. Could be heavier pistons than stock or the difference in the ring packs or even bore finish.
Old Jan 10, 2025 | 01:28 AM
  #34
spanks13's Avatar
SBE LS7's are magic. Everyone is getting scared of LS7's because of the rods and the valve guides, and I just want to buy more while the parts are still available haha.
Old Jan 10, 2025 | 02:12 AM
  #35
yup. Something about an untouched shortblock just works
Old Jan 10, 2025 | 04:32 AM
  #36
jayyyw's Avatar
I wholeheartedly believe I would have eclipsed 800whp with my heads/cam/intake setup on the SBE LS7. Just too problematic for most people. They just want to beat on it but that motor needs to be maintenanced well. Sleeves, valves, rods, pistons, etc are the weak links. Been seeing a lot more ring land failures on them, lately.
Old Jan 10, 2025 | 06:24 AM
  #37
yea the kicker for me is the sleeves. I would chance the rod coatings, but I can't chance the sleeves. So that's more power means more cylinder pressure. I went with Darton sleeves
Old Jan 10, 2025 | 10:18 AM
  #38
Ryans99ls1's Avatar
If you end up wanting a BTR trinity, I will sell you mine at at great price. The 112mm adapter is removable and it's ported by Ironmask. I am sticking with the MSD since it's better suited to my cam specs.
Old Jan 10, 2025 | 06:15 PM
  #39
im still months away from testing it and seeing what happens unfortunately
