The 830HP pump gas 434 that could
My past 408 was a strong runner but being iron and adding a 4l80 made my car feel like a tank. The goal of the new build was to save weight by going back to an alum block and utilize a 4.1 bore to take advantage of the strong square port head market. It will be street driven so target peak power was 7500 and had to be run on 93 pump gas. I was fortunate enough to grab one of the last ERL sleeved 5.3 blocks before they pulled the plug on their business.
On a 3rd party independent engine dyno with a carb it made 830HP @ 7500, peak torque was 626lbs @ 6200 rpm. Target shift point will be ~ 8100/8200. Recently swapped to Holley Dominator EFI so tuning is underway.
Here's the parts list and pics. Some info I either don't have offhand or is witheld bc of engine builder
ERL sleeved Gen IV aluminum block (additonal machining/ build by Bammann Racing Engines)
Brodix BR7 heads (porter casting) CNC'd by FED
2.25 Ti intake and 1.614 exhaust
Callies Compstar 4" crank (from 408 build)
Callies Compstar 6.100 rods (from 408 build)
Diamond custom pistons (compression is >11:1 but less than 13.5:1
Solid roller cam by Straub Technologies (specs witheld)
Crower stainless shaft mount rockers
Huge *** Trend 7/16" pushrods
Morel Black Mamba lifters
PAC Racing Springs
Melling oil pump
CID 4.0 intake & Accufab 4500 throttle body
Moroso 3 vane vacuum pump & Meziere elec water pump
Custom fuel system by Bammann w/ Aeromotive fuel pressure regulator & Bammann fabricated mount
Also has Squash Performance dual Walbro 450 in tank fuel pumps -6 & -8
Custom flexible steam vent kit by Bammann Racing Engines
GM truck coilpacks
Firecore wires
Katech valve covers and coil mounts
ARH 2" headers w/ 3" collector
Enjoy!
http://www.aeicnc.com/
The prior 408 likely made ~650/660HP at the crank but was out of breath by 6400 rpm thanks to a FAST intake. The new powerplant is ~175HP more assuming it'll top out around 8k rpm.
I have a 429 build going and plan on using a short tunnel ram but will be trying the CID 4.5 on the dyno for kicks.
