The 830HP pump gas 434 that could
https://www.enginebuildermag.com/201...hallenge-2019/
Funny with a Builder vs... 800 is all that's wanted. And a tight as Dyno...
C those numbers are Fake news...😉
Why would the “big” heads hurt it? What makes them big?
It only made 1.44/in torque. How much do you think it was “manipulated”?
Because you and your friends can’t do it, that means it can’t be done?
So what is it OP? Are those pistons domed or dished. We have diamond nitrous pistons and are at 12.2:1 compression. They have a -3cc dome and sure don't look like the other ones pictured to me.
as I said @ first...more surface area
this 1 made 800 before 8k with less just a bit more compression...
https://m.facebook.com/story.php?sto...4&id=650540763
Give it up...your builder is Trash just like I got robbed...Would you like the ET? 8 seconds or the 8th Mile? Sub six..
What ET are you all seeing is what needs to be asked with a tight *** Dyno or under performing build and builder.
I'll gladly race any donkey car you mention above on motor on the street. Name the $$$
My guy will come in generally if I post....
Also showed me how to make my own head and parts work @ a Fraction of the cost ....
For FREE thru a PM.
Last edited by Che70velle; Feb 26, 2020 at 03:26 PM. Reason: Useless...totally off topic info...again
Again, because you’re not doing it doesn’t mean it can’t be done. Spend a little more time critiquing your stuff instead of everyone else’s and you might make some progress.
If you stay stuck in the “I can’t” and “it can’t”, you never will.
I also think that sending letters for those purposes is a low act.
well teacher has spoke
