Help with valve height and pushrod lenfth
hey brother, yes I will follow your notes precisely.
hey man just running through the steps in my head again and need your opinion if I am doing it right lol .
Pushrod length: Install gaskets, torque heads, snug rocker arm, measure with adjustable pushrod to zero lash (using heavy springs already installed) take measurement of all 16 pushrod lengths with micrometer. Add lifter pre load and order pushrods.
Well now my crushed head gasket can't be ran…
Pushrods show up...
Piston to valve clearance: install crushed head gasket, add some clay to cylinder 1 piston only, install pushrods, set to zero lash again, rocker arm snug, install lightweight checking springs (to avoid lifter collapse) to cylinder 1 only, rotate engine twice and then take heads off and measure clay depth.....
But now I need to order yet a second head gasket lol
How can I avoid buying a second set of head gaskets?
All you need is something of the same thickness (or "close enough"... no 2 are "exactly" the same, anyway) to put between the head and the block. Washers, cardboard, sheet of aluminum or plastic of some kind, ANYTHING that takes up the right amount of space, it makes no difference. Use whatever "spec" the gasket mfr gives you, and accept that whatever the ones you buy do that's "close" to the "spec" when you install them, simply HAS TO BE "close enough", not least because it's IMPOSSIBLE to get it any closer. Don't even need to "torque" the head bolts; again, "close enough" will get you ... close enough.
"Measure with micrometer, mark with chalk, cut with axe". Don't fall into the trap of thinking you have to have a micrometer reading down to the .0001" that's been certified within the last year when you're measuring a 2x4 and all you have in hand to cut it to length with is a Jeffrey Dahmer saw. Let a little reality intrude on pointless and unobtainable "perfection".
Pushrods show up...
PTV should be checked prior to putting heads on and once it’s determined it’s ok, your done with the long block. Once the heads are torqued then move on to rocker wipe pattern and pushrods. Pushrod length does not affect PTV, so no need to pull the heads back off.
