Am I reading my piston specs correct?
Old Jan 17, 2025 | 06:50 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Am I reading my piston specs correct?
If I am looking at this right, I have dome top pistons with +3.3cc piston volume? If I remember correctly, they did look like they had a dome top.
Old Jan 17, 2025 | 08:06 PM
Eric, the “dome” you have is basically canceling out the valve reliefs, making this a true flat top piston, per say. In other words, you have 3.3cc worth of reliefs, and 3.3cc worth of domes. Very common for compression engines.
​​​​​​…..edit….who made this piston?
Old Jan 17, 2025 | 08:57 PM
FCar2000TA's Avatar
Veteran: Air Force
CP-Carrillo.
Old Jan 18, 2025 | 04:20 PM
FCar2000TA's Avatar
Veteran: Air Force
Now I want to take an engine building class. So, this whole process has me wanting to take tuning classes, welding classes, and now engine building classes. hahahaha. I guess I know what I want to do when I retire. Too bad that is still at least 15 years away. By then the car might be on the road.
