Pistons for LH6
The engine has AFM but i am going to delete it and no VVT
Thanks for any advice !
799 chambers are a bit larger, so using these pistons with 799 heads will lower compression somewhat.
You can buy replacement pistons from Engine Tech, Speed Pro, Silv-O-Lite, Mursa, Nippon and few other companies.
I've heard of this practice on other engines, but not the LS.
He too agreed with me and added that this method was common in early NASCAR engines.
A "backward" installed Offset Pin Piston will ADD Dynamic Compression and the engine Torque Range will have a HIGHER peak.
Thus a "poor man's" LR engine.
The piston will remain higher in the cylinder as the crankshaft turns after combustion.
This effect allows for smaller intake port sizes.
Lance
Lance
Yes, when I spoke to him, he was surprised.
He did this because he could NEVER get work finished due to interruptions!
