Gpi ss4 nfc
Old Jan 30, 2025 | 10:02 PM
Clint10!'s Avatar
Default Gpi ss4 nfc
I was just wondering if anybody has had there heads milled on ls3 with this cam (gpi ss4 nfc) and if so did you have enough vavle clearance.
This is the exact numbers
Old Feb 1, 2025 | 07:30 PM
I haven’t ran that camshaft, but on an LS3 (OEM pistons) with a much smaller camshaft, I had to fly cut. No way that cam is going to work with LS3 heads, especially milled heads on true flat tops.
Old Feb 2, 2025 | 09:11 PM
Bob570's Avatar
The NFC stands for "no fly cut", but if I remember correctly it specifically says on the website that you cannot mill the heads.
Old Feb 3, 2025 | 01:00 PM
1988montecarloss's Avatar
x2
gpi says if they are milled at all you will still have to flycut
i run a slightly smaller cam in mine and have 823 heads decked .030" and had to flycut
only way to know for sure is to PTV clearance test it yourself and go from there
Old Feb 3, 2025 | 02:45 PM
low2001gmc's Avatar
MASS seller approved
NFC is for No Fly Cut with Unmilled Heads as others have mentioned. Always best to check PTV Clearance though.
PTV Clearance is based both on Intake Duration and LSA.
Old Feb 4, 2025 | 01:07 PM
Rich2342's Avatar
Go with an 11 degree LS3 head and you wont have to flycut. You have extra valve clearance and can mill some to boot.
Old Feb 6, 2025 | 12:07 PM
lazerlemonta's Avatar
I fly cut my pistons .120 when i got the 281cc heads and cam from them. Also used 040 head gaskets.
