500 hp na 6.0
500WHP is alot more than the 530 crank hp that is advertised in that package
for 500whp through a t56 out of a 6.0 youll want a rec port head, 11.5:1+ compression, holley highram or similar intake and lots of cam and rpm which means good valvetrain parts
stay away from all of those cheap fabricated intakes theyre junk and make less power than stock NNBS truck intakes
youll also need way more than 36 lb/hr injectors and will probably want steeper gears than 3.73
I'd source some cheap 706 heads ($50 at our local junk yard). Decent valve job on those and mill .050 off or so. Home port if you know what your doing. Then run one of the cheap stg2-3 sloppy cams. YOu'd hit your goal or more for half the cost of the setup you mention above.
E85 can often make less power NA if you don't truly need the octane because the fuel takes up more space in the combustion chamber. I wouldn't expect a power gain just because.
Even at factory compression E85 nets decent power gains over pump fuel. Its usually 6-10%+ more power at the crank. A really healthy motor that is unable to run PK TQ timing on pump gas will pick up big from E85 alone.
I’d really do rectangle port heads and a L92 manifold. I’d reach out to cam motion for a custom cm pending what power and you’ll be living in. 500 whp is going to be difficult imo and be drivable.
