Would you use this oil pan gasket?
Old Apr 21, 2025 | 05:43 AM
StorminMatt's Avatar
Default Would you use this oil pan gasket?
I got this AC Delco gasket from walmart.com. And I guess there must have been a problem with the handling of the gasket, which left it bent. Is this simply a matter of straightening it? Or should I just return it and buy one at the dealership (that I can inspect before taking it home)?
Old Apr 21, 2025 | 09:00 AM
IF it can be straightened easily enough to function properly, I see no issue. It's not exactly a high stress critical part.
Old Apr 21, 2025 | 02:09 PM
On the other hand, it’s not an easy part to replace should it leak.
