Help with compression ratio calculatio
Old Jul 13, 2025 | 11:55 AM
Geworthomd's Avatar
Default Help with compression ratio calculatio
Can anyone help me with compression ratio in two different scenarios?
1. LS3 73cc heads 4.0 x 4.0
2. LS3 73cc heads 4.0 x 4.125 stroker
A friend has some mew Trick Flow 73cc that he wants $3300 fully assembled. I will add Pro Charger 10 to 20# and octane boost or water injection . This isn’tsn’t a daily driver.
i have not yet purchased the pistons nor the MLS gasket
Old Jul 15, 2025 | 09:28 PM
The 4” stroke engine with a .041 x 4.160 headgasket and a 5cc flattop piston at zero deck will be 10.48:1
The 4.125 stroke engine with the same parameters will be 10.75:1
I’m moving this to Internal Engine…
