Cam change? Change my mind....
Old Jul 17, 2025 | 02:15 PM
RollingDumpster's Avatar
Default Cam change? Change my mind....
I am very happy with my combo and any normal person would leave it alone. Well, I'm stupid and can't leave well enough alone. I am considering a cam change to alter the sound of the combo. Sounds stupid right.
Current combo:
1990 RS
  • 11.5 CR 377LS3
  • Mamo 235 Cathedral Ports
  • Comp 227/232 114+3 .614/.610
  • Mamo ported FAST 102
  • NW 102 TB
  • Mamo 10mm Yella Terra Rockers with Manton pushrods
  • Johnson Tie Bar with axle oiling lifters
  • Tremec Magnum with Mamo RPS BC2 Clutch
  • Trick Chassis ford 9" with 4.10 gears
  • True Dual 3" exhaust with cats
This combo put down 515 at the wheels (dyno was with 10 bolt and 3.42's) on a mustang dyno. Power is smooth and everywhere but doesn't sound very rowdy at idle as the cam has only 1.5 deg overlap. I am considering the comp 54-549-11 cam 231/239 @ 113 .617/.624. It adds a few degrees and yields 9 degrees of overlap. This cam would shift my powerband a little north but probably not by much. I don't want to lose too much power down low and it certainly must idle in traffic with the AC on. The recent addition of the 4.10's also helps offset any low end loss.
I am really only considering this because I may have to go with another clutch as I somehow managed to damage my RPS unit. Its being evaluated but if I have to change units, I will be adding weight and will likely need a new dyno tune anyways.
Talk me out of this.
Old Jul 17, 2025 | 06:56 PM
Current combo:
1990 RS
  • 11.5 CR 377LS3
  • NW 102 TB
You can easily alter the sound of this at idle with the tune. You can lower the idle speed and activate the idle spark adaptives, among other things. I know enough about tuning to be dangerous…reach out to your tuner and ask questions….save yourself a bunch of money, time, and headache.
Old Jul 17, 2025 | 10:40 PM
showdog75's Avatar
Also if you're dead set on a cam change call Mamo, he knows his stuff best. Tell him what you want and what you do and don't like about your current cam.
Old Jul 18, 2025 | 08:02 AM
MuhThugga's Avatar
Agreed. I remember 15 years ago when tuners were marketing "ghost cam" tunes so cars with factory cams would sound like they had a Stage 6 Big Dick Inseminator installed.
Old Jul 18, 2025 | 08:26 AM
I will. He spec'd my current cam. I will likely decide after I find out the fate of my clutch. I did think of the tune part of it, but not sure I want to go that way. I'll keep pondering.
Old Jul 18, 2025 | 07:40 PM
68Formula's Avatar
If you're looking more for sound, the LSR version will give you a little more and keep the powerband similar. It's a 227/243 113+4. 9 degrees overlap. 42.5* IVC vs. 43.5*. Still pull a little higher in rpm.
https://www.compcams.com/lsr-rectang...ii-iv-cpg.html
Old Jul 18, 2025 | 08:16 PM
I did look at that cam but not sure I need that much duration on the exhaust. Cathedral port for me right now.
Old Jul 18, 2025 | 09:39 PM
wannafbody's Avatar
Playing with spark timing at idle can give it some chop/ I think +12/-12 works.
Old Jul 18, 2025 | 09:44 PM
68Formula's Avatar
If you want to keep a similar powerband and mostly just change the sound, the "Rec Port" cam will accomplish that due to it's additional overlap (result of higher exhaust duration having later EVC and additional advance having slightly earlier IVO).
Here's an example where RH tested the "cathedral" versus it's "rectangular" port on a cathedral port head. (He also compares both on a rec port head). Similar curve, more aggressive idle. Start at the 2 min mark.
Old Jul 19, 2025 | 12:03 PM
wannafbody's Avatar
Cam Motion had a dyno graph of a 229 duration cam that put up good numbers.
Old Jul 19, 2025 | 03:18 PM
DualQuadDave's Avatar
The Mamp stuff typical prefers smaller splits, his exh port works very well. Don't take any of the advice here for cam recommendations, I would call him and re-spec for bigger combo. That being said a, Scoggin Dickey 232-236 113 cam will make very good power in that combo and it's cheap. Just depends on what you want. Honestly, since you have roller rockers, put some serious springs in it and crank up the lift. .680-720. It's power that's already there, just cam it right and start the party💪
Old Jul 19, 2025 | 03:57 PM
Bob570's Avatar
I'd be looking at a BTR stage 3 LS1/LS2 V2 cam or a Cam Motion Titan 5. Both will do really well and should drive really well on your setup.
Old Jul 20, 2025 | 07:12 AM
showdog75's Avatar
One question I'm surprised that's not been asked yet being a Mamo combo, are you running 1.7 or 1.8 Yella Terra's?
Old Jul 20, 2025 | 07:04 PM
Pretty sure 1.7. Ill have to go back and check my paperwork. I will endnup going through Tony, im just playing mental games with myself now.
Old Jul 20, 2025 | 07:16 PM
DUSTYWS6's Avatar
Get some electric cutouts and lower your idle.
Old Jul 22, 2025 | 09:56 AM
1988montecarloss's Avatar
if youre just looking for the sound at idle just adjust it in the tune as others have said
Old Jul 23, 2025 | 02:15 PM
old motorhead's Avatar
And pull a plug wire or two off.
