6.0L Iron Block power limit?
Old Aug 13, 2025 | 08:32 AM
SaudiSpeedLS2's Avatar
Default 6.0L Iron Block power limit?
Basically the title. How much power (and boost) can a Gen 4 6.0L Iron block handle assuming the rotating assembly has infinite strength? Also ive heard people saying that the Iron blocks can fall short of the 9.240 inch deck height, what do they mean by this, why is it a bad thing?
tyyy <3
Old Aug 13, 2025 | 08:43 AM
Tommy42088's Avatar
Sounds like you need to do alot of research. Your not going to get many responses from a generic question like this. You need to be much more descriptive, a full detailed build. Parts list, is the block sleeved? Also you mention how much boost, you need to list what turbo your planning to use, all turbos are different. You may have 1 turbo that may created 800 hp at 20 psi and then you may have another that may create that same power level at 14 psi. Also tune plays a big factor, who's tuning? What kind of fuel are you planning to run? Is this through a manual or automatic transmission? Do you get my drift?
Old Aug 13, 2025 | 09:09 AM
My question is generic on purpose. I want a general idea of how strong an untouched Iron block 6.0L is, while assuming perfect conditions on an engine dyno, where the block is the weak point. I stated "assume rotating assembly has infinite strength" for this reason.
Old Aug 13, 2025 | 12:35 PM
1FastBrick's Avatar
When you start pushing past 1000HP, It starts lifting heads. Guys have hit between 1200-1500 HP with the factory block but they don't seem to live to long. You need to go to a block that has 6 bolts around the cylinder Vs.4 on the factory block.
Old Aug 13, 2025 | 02:00 PM
1988montecarloss's Avatar
as said above, youll get to where youre lifting heads or pushing the thrust bearing out of it
there is no finite answer to this question but they will get well into 4 digits
Old Aug 13, 2025 | 05:25 PM
Duration is the question….how LONG do you need it to last. It might hold 2500…for a few seconds. It can hold 1500 with ARP aged Headstuds for a season. RPM plays a major role here also, as you’ll knock the caps off the bottom of it north of 10k…again duration of time is the annswer. Application is everything.
Old Aug 14, 2025 | 10:19 AM
When the block cracks/fails do the internals go with it or do they survive to get thrown into another block?
(At about 1000-1500 horses)
Old Aug 14, 2025 | 12:37 PM
no different than asking will i win the lottery today or not
Old Aug 14, 2025 | 01:56 PM
Forcefed86's Avatar
Lots of ways to keep the heads down over 1000hp. Even with standard ARP hardware. Its all about limiting peak cyl pressures. Drop your base compression down to 8:1 (or less even) and you can make the same 1000hp+ with much less peak cyl pressure which is what lifts the heads. Combine that with not loading it hard around PK TQ, limiting timing, and revving it high. Then head sealing will be much less of an issue. Head sealing gets to be a problem when guys are pushing 10:1++ base compression, tons of boost, and pushing timing and power at early RPM power.
The 6.0 blocks frequently crack between the cylinders in the water jacket. Which is much more of a weak link than head sealing. Which is why guys get so much farther with the 5.3 Siamese bore alum blocks. But the core still shifts no matter what you do and you can see that in the caps. Even with the best crank/rods/pistons. Around 1200hp you can see fretting in the caps right around 1200 crank due to the block itself moving.
The 1200CHP number is from Kurt Urban. He has dug into hundreds and hundreds of performance LS motors.
Old Aug 14, 2025 | 01:58 PM
Yeah…trick question really. Depends on the severity of the fail. Takes a major block failure to hurt the crank. Rods rarely get hurt, but are subject to how many cycles are on them AT RPM to determine their lifespan. Pistons/rings are a consumable and get tossed often, unless there’s virtually no time on them. I re-ring every time I tear down, even after 1 dyno pull…so obviously rings are throw-aways to me, even the $400 Total Seal exotic stuff. Same with bearings due to crush factor…I don’t reuse them ever in a running engine. I will keep a nice set occasionally for mock-up stuff drawer.
Old Aug 14, 2025 | 03:33 PM
Tommy42088's Avatar
What are you trying to accomplish?
Old Aug 14, 2025 | 08:32 PM
Bbknucks's Avatar
I dont think he is trying to accomplish anything
Old Aug 14, 2025 | 08:36 PM
I am actually. My main goal is drag racing, and I am asking these questions to decide on an engine and guesstimate how long said engine might last at different power levels.
Old Aug 14, 2025 | 08:58 PM
Bbknucks's Avatar
See now with actual details on usage and application you can get some valuable feedback instead of just hypotheticals
