Ring thicknesses?
Old Oct 14, 2025 | 12:02 PM
HappySalesman's Avatar
Default Ring thicknesses?
Been doing some research and just learned that the LS2s that came in the TBSS and SSR came with a 1.5/1.5/3.0mm ring package, whereas the LS2s in the passenger cars had a thinner set, 1.2/1.5/2.5mm.
I know a thinner ring is less friction, seals better, etc so it frees up more power, but why would GM run a thicker ring set in the truck motors? Would there be any massive detriment if you ran the thinner set in a truck motor?
Old Oct 14, 2025 | 12:09 PM
RB04Av's Avatar
Thinner = better sealing etc.
Thicker = lasts longer esp when not perfectly clean
Pick your poison
Old Oct 17, 2025 | 11:07 AM
pannetron's Avatar
GM assumes trucks will tow and run at higher typical loads.
Old Oct 17, 2025 | 12:31 PM
RB04Av's Avatar
And in dirtier places with less maintenance.
