CAM recommendations
Old Mar 14, 2024 | 04:31 PM
Scott Danforth's Avatar
Default CAM recommendations
looking at a cam for my next project. engine is an LS4 longblock, running a carb and sitting in a Fiat 500C Topolino Belvedere wagon with an AR5 running a dual disc clutch and C4 suspension with 3.07:1 and a 26.85" rear wheel
Target weight is 2200# (1100kg) without driver
car may see an auto-X course or a drag strip, however will be driven nearly every week when weather allows (face it, its not rain friendly). it will be used for trips and errands.
looking at the following 3 cams. Comp XR275HR, Comp XR281HR, and BTR Hotrod cam
looking for decent street manors above 1500 RPM (no bucking, etc)
COMP 275 222/224 .566/.568 112
COMP 281 228/230 .571/.573 112
BTR HR 217/241 .619/.617 114 +3
what do you recommend and why. trad mag dyno results only tell part of the story. looking for real world 5.3/manual/ultra-light vehicle responses.
Old Mar 14, 2024 | 05:17 PM
00cls1camaross's Avatar
the smaller the cam, the more torque down low it is going to make. The smaller cam is also going to drive better and have better street manners. I would vote the 222/224 for these reasons.
Old Mar 14, 2024 | 05:52 PM
Appreciate the reply
The car is so light that first and second gear will be nearly useless. Not needing torque down low.
Originally thought of an LNF, however for the same physical space, I can have 2.5x the power and V8 rumble
I'm concerned about cam stability at light throttle/light load to not have drive-line rubberbanding
Old Mar 14, 2024 | 06:40 PM
68Formula's Avatar
Single or dual plane? What carburetor? Long tube headers or shorties (and what size primaries), and size exhaust?
Old Mar 14, 2024 | 06:54 PM
Single plane, HP830 annular. (Although I have a plethora of carbs between 715 cfm and 950 cfm)
Headers will be between a shorty and long-tube as they will be custom to fit. Dumping into 2-1/2" dual exhaust with an X- over. Mufflers when needed.
Old Mar 14, 2024 | 07:31 PM
Doug G's Avatar
No experience with those 3 cams... but for what you're asking...I like the BTR cam.
Wider LSA spreads the power out Vs a smaller LSA being "peaky"
Old Mar 14, 2024 | 07:49 PM
68Formula's Avatar
Summit 8715R1 222/234 115+3 .600/.575 would work well in a 5.3L with <2500lbs and carb.
The extra exhaust duration will help get the spent gasses out, yet with -1* ATDC exhaust closing it'll mitigate exhaust reversion with shorty or mid-length headers. It's -2* overlap will give a good carb signal even with the single plane and that size carb, providing decent part throttle response; and have a really broad power range @ WOT (especially mid to upper). So if you do autocross, it'll get off the corners without too much downshifting and pull all the way to 7k. Probably just soft enough on the low end to keep from blowing the tires, but still feel really strong.
Old Mar 15, 2024 | 11:25 AM
Isnt the summit ghost cam (8715R1) a cam for boosted motors?
I dumped all the cams above into dyno2000 just to have a comparison. short of a slight bump in power on the XER281 to the XER285, the others are about even.
the BTR hotrod cam is about on-par with the comp 281. however with higher lift than the comp. from a spring longevity point of view. there is a nod to the comp.
all have over 300 lb-ft of torque at 2000 RPM. all about 200 lb-ft more than it will take to spin the tires in first and second in a car that is 11 ft long and is having its wheel base stretched from 78" to 90" to fit the motor.
Old Mar 15, 2024 | 06:31 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Cam Motion LS1 Titan 3 ( 224/228 113+4 .603/.595) would be my suggestion for a medium aggressive 5.3 in a sub 2400 lb car.
Cam Motion is famous for smoother lobe profiles & exceptional customer service.
Easy enough to call and get something custom specced as well.
Old Mar 16, 2024 | 07:13 AM
This one? https://cammotion.com/recently-resto...224-228-113-4/
Old Mar 16, 2024 | 10:20 PM
68Formula's Avatar
It's actually not, but it still works well on boosted motors. So @Summitracing also listed it as their Stage 1 Turbo camshaft when they launched their turbo cam series. But it was originally listed as their N/A Stage 1 LS camshaft.
Don't get too attached to naming conventions. It's the valve events that are important.
Old Mar 17, 2024 | 12:13 AM
Yes..
Old Mar 17, 2024 | 06:13 AM
Tuskyz28's Avatar
At 2200 lbs i would be looking at a bigger cam... lighter cars can get away with more cam
Old Mar 17, 2024 | 06:56 AM
grubinski's Avatar
I drive my LS3 Miata on the street essentially daily. It’s 2400#. When I had a rowdy cam in it, any lack of manners due to the cam was reflected *immediately* in jerky behavior of the vehicle. I went to a milder cam (227/232 114LSA) and the car drove much nicer. I think the OP is on the right track with a 224/228 cam. Given that it’s only a 5.3, if it was me, I’d go milder … but I’m super old. 🙂
Old Mar 17, 2024 | 11:45 AM
I'm Vintage and going Chrome myself. Is your Miata an automatic or manual?
Old Mar 17, 2024 | 03:06 PM
automatic? really?
Cmonn Mann
LOL
Old Mar 17, 2024 | 05:30 PM
Originally Posted by NAVYBLUE210
automatic? really?
Cmonn Mann
LOL
some people like them..... i hate them. hence the reason I asked
Old Mar 17, 2024 | 05:53 PM
grubinski's Avatar
Manual. No power steering, power windows, windshield washers, stereo, traction control, abs, clutch safety switch or other nanny state BS.
I’m a neanderthal … neanderthals like to row their own gears. 🙂
Old Mar 17, 2024 | 05:58 PM
68Formula's Avatar
I don't see manual brakes in there, so that'd at least make you a a Cro-magnon.
Old Mar 18, 2024 | 11:10 AM
I will be running tilton manual brakes with a custom pedal assembly..... that keeps me in the neanderthal ranks...... more of a troglodyte...... for this build, a bit of a Luddite, just dont want electric/power/automatic anything in the Fiat build because todays cars have soured me on electrics/electronics/automatics
Just read a comparison article listing Crane cam (.590, 224/232, 114 lsa).
https://www.streetmusclemag.com/tech...ew-327-vs-lm7/
https://ls1tech.com/forums/forced-in...-cam-test.html echos the high RPM gains.
Summit is recommending the 8704 https://www.summitracing.com/parts/sum-8704, however have yet to answer the part-throttle low speed stability.
