Metal Shards throughout L92 - Source?
Here is an overview and my working theory. Please comment if you think this makes sense or if I should check anywhere else. The motor is torn down to the bare block at this point.
- Issues
- Glitter / Metallic Flakes and smaller scraps found in oil pan + oil pickup
- Metal shards (see photo) found in under valve covers near valve springs and oil return holes + under valley cover
- Vertical scoring on cam and lifter roller
- Inspection
- Cam Bearings - Some install wear but look newer
- Rod Bearings - No unusual wear
- Main Bearings - no usual wear
- Pistons - All rings and ring lands account for. Some vertical scoring on piston skirt thrust axis showing signs of contamination in oil
- Dual Valve Springs & Ti Retainers - Some wear on the bottom of the retainer where it meets the spring, but nothing matches to the shards
- Valve Stem Seals - Wear on the lower 'hat' portion
- Theory
- The previous owner installed dual valve springs with OEM 1 piece valve stem seals leading to excess wear on the larger OD of the valve steam seal 'hat'
- Setup
- L92 - Stock Bottom End
- LS3 Intake, DOD / AFM / VVT Delete, LS3 Valley Cover
- Comp Cam Kit with Dual Valve Springs, Titanium Retainers, 7.4" Push Rods, Trunnion Upgrade Kit
Pictures
LS7 Lifter - Vertical scoring (matching cam lobe wear)
Metal Shards found under valve cover
Metal Shards found under valley cover
Dual Valve Spring with OEM Valve Steam Seal showing wear on lower hat. (These valve stem seals are smooth but show wear).
Dual valve spring interferes with hat at rest, but once installed seats on lowest seal face
Rick
The rockers with the trunnions and bearings removed
Left - Comp Cam Trunnions, Middle - Bearings with Race in tact, Right - broken race bearings
Comp Cam Trunnions with wear on bearing journal and rail seat
Bearings with broken races
Bearings in tact
Lifter Rollers
Is there any correlation between worn trunnions and failed bearings?
Rockers look fine. You could very lightly polish the tip of the rocker with some metal polish, but thats basically what they look like with any kind of use.
- Issues
- Inspection
- Theory
- Setup
Pictures
Remember the lifters have a max spring pressure rating. I say this because I don’t know what your plans are for lifters. I’d be weary of reusing the lifters as they might have debris in them. At least disassemble and clean them.
I pulled the trigger on the CHE bronze bushing trunnion kit with new BTR rockers and the BTR 0.660" dual spring kit for my summit 8707-R1 cam
125lbs is more than enough seat pressure. The guy the built it first was wrong.
