Measuring piston to valve clearance
I have a forged ls2 short block that I had a shop machine and put together for me (very reputable). I decided I would do the rest. Had the heads resurfaced, installed some new Che trunnions, new BTR stage 2 boost cam, melling pump, ARP main and head studs, BTR platinum spring kit etc, it’s an s480 big turbo build.
Purchased and installed Johnson 2116lsr lifters because I’m too paranoid of fake ls7’s or just the lifters turning in trays in general…. anyways, I measured my pushrod length 3x (triple checked lol) and sent the numbers to Manton.
Got my custom length pushrods yesterday…. Now I need to measure piston to valve clearance is my understanding of last step before I put accessories on.
Here’s my question… since my cam is somewhat large I understand it’s proper to measure PTV since it’s not a short duration cam. So, I plan to do the method where you add clay to cylinder 1 exhaust and intake, rotate engine, get the impression on clay and then measure impression for clearance.
My question here is, when I turn the engine over it will likely compress the lifters and oil content, so will I get a false measurement?
Pull the snap ring on the lifter and replace the spring in it with a stack of washers
Use a check spring under the valve keeper
I normally use playdough to check clearances
During an engine build P-V is often checked after TDC has been determined, a degree wheel has been setup, the camshaft has been installed and the valve events have been verified against the cam card. The closest P-V measurements are typically within 10° before and after TDC.
I ALWAYS use modeling clay for finding PTV. I use checking springs on cyl #1, so hydraulic lifters aren’t a factor. The clay won’t lie. Turn the engine over two full revolutions to do this. I use .030 steel valvespring shims under the heads while turning it over by hand. If I’m using a .040” headgasket…which 98% of my builds use…I simply ADD .010 to my numbers i found in the clay. It’s super easy. Snug the head while doing this, so you don’t hurt the head with the shims. The shims have the correct .500 hole in the center of them for the head dowels and headbolts to go through. I use 6…4 at the corners and 2 in the center for support. I only use a few headbolts, again hand tite snug. Pushrod length to do this step is determined during a mock-up stage….it’s usually VERY close to stock length for the style of engine. I determine my final pushrod length…all 16 valves…in my final step after heads are final torqued. That’s the last step, unless it’s a solid roller…in which case setting lash would be my final step before valve covers go on, and it’s ready to fire.
I just get on tech and ask every on what will fit...
If it's on the internet, It must be true...
