Noise on LS3 415 Stroker
Is this to be expected from a 415 stroker? I assume pistons have to be shorter and probably poke out the bottom of the cylinder making them more unstable, but should it still go away or is it just how it is?
Build specs:
415 ci LS3
LS3 block/ heads
Scat forged 4.0 stroke crank
Scat 6.125 forged rods
Mahle forged pistons 4.065 bore 10.8:1 compression
King rod/ main bearings
HV Melling oil pump
1.7:1 rocker arms
Ls3 intake manifold
87mm throttle body
42lb hr LS3/7 injectors
GM LS9 camshaft
Build specs:
415 ci LS3
LS3 block/ heads
HV Melling oil pump
1.7:1 rocker arms
Ls3 intake manifold
87mm throttle body
GM LS9 camshaft
And yeah the ls9 cam is a terrible pick for this application especially considering THEY MADE IT CHOP AT IDLE WITH THE TUNE!
Just trying to figure out whether to tell him to let it ride or take it back. It has 1300 miles on it.
If you bought a ls3 stroker and it sounded like perry the platypus at operating temp would you send it back or run it?
Also Dawsonville GA? We're neighbors basically.
My LS1 has pretty bad piston slap. It's also got 115,000 miles on it but it runs great. I don't know that piston slap is the end of the world.
I'd rather a smoother idle via a cam like the Ghost cam that delivers good power with a smoother idle. A sleeper.
