LS2 intake on LS1 (with pics)
Edit: I guess this answers my question. A bigger PITA than it's worth...
https://ls1tech.com/forums/generatio...ntake-ls1.html
I have a early 2007 GMC savana van 4.8L engine 24x ignitoin small delphi injector plugs.
I need to swap to a LS2 intake to clear the firewall, and I need to swap to a bolt DBW throttle body to be compatable wiht the E40 PCM that I need to work in my 2004 colorado.
my question is there anyway that I can reuse my injectors on a LS2 intake, wiht LS2 fuel rails? I want to avoid the cost of new injectors at 200.00 and new injector plugs, or plug adapters, also I don't have any other mods to the engine so larger injectors would be useless! can't I just remove the plastic nub on the injector and use new LS2 orings? maybe I need rail or injector spacers?
