3 valve heads- advantages and disadvantages
There is a discussion on another forum regarding the merrits of a 3 valve head, such as the design many people think the LS7 will employ.
To me, a 3 valve head makes sense. You get more air into the the engine, without the problems you encounter in port velocity and smooth airflow when you use one big valve instead of two smaller ones.
However, someone on another forum seems convinced that a 3 valve head is inferior to a 2 valve head.
I'm no automotive engineer, but that doesn't make any sense to me. If I'm wrong and he's right, can someone explain why?
Let's discuss!
It doesnt matter if its had sufficent development, there are performance benefits of only having 1 intake vavle. This comes in at low and mid range levels and is why the Viper and Corvette have about the broadest powerbands in the world. A 3 vavle head will either lose that broadness or the motor will gain in complexness but it will lose in gas mileage. It will gain a bit of top end Horsepower though, but they can more then reach their goals in power without it. And it wont be that big of a gian anyhow, and wont be any gain at 6,500rpms.
Let's discuss!
more air = more power
He also said:
And I do not want to see the 3 vavle head on the motor for it will hurt the low and mid range torque requiring the motor to become even more complex. That will also greatly add to the price.
Here's what the SAE thinks about the design:
To further extend the life of the Generation IV V8 and its revised High Value V6 engines, the company has devised a three-valve head design to work with these pushrod engines. Adding a second intake valve improves intake air flow, which provides some value, but perhaps more importantly the design relocates the exhaust valve and the spark plug within the combustion chamber. The exhaust valve moves from alongside the intake valve to the other side of the cylinder, so less exhaust heat transfers to the intake port. The resulting cooler intake charge boosts power and efficiency. Positioning intake and exhaust valves on opposite sides of the combustion chamber leaves space in the center for the spark plug, which improves combustion efficiency. Together, these improvements boost power output by 10-15%
Originally Posted by Another_User
I think it is just a gimmick. I have saved a couple pictures of the "three-valve" heads. Pretty weak. Both of the intake valves are connected to a single pushrod. You end up with more valvetrain mass, maybe a little better flow (if the air doesn't have to dodge oddly-shaped intake ports), and probably valve float. It's a lame-*** way to put a spin on dying technology. Don't get me wrong, pushrod engines are awesome, and will still be around for a long time. But overhead cams and variable valve timing make for less moving parts, increased efficiency, and more power. I think GM is just stalling, and giving everyone some "eye-candy" while they (budget permitting) get ready to build a real V8. Or they could just be lining up to screw us like they did when they killed the F-body and made the lame-*** looking GTO. Weak GM...very weak.
As for OHC technology, it's been around almost as long as pushrod technology. OHC motors are generally heavier and less efficient (specifically when it comes to fuel economy). I could go on, but I believe that arguement has already been beaten to death.
https://ls1tech.com/forums/showpost....2&postcount=24
3-valve heads a gimmick? Seems like A LOT of effort that will do nothing but **** everyone off in the end when they don't deliver. GM's made some dumb mistakes IMO, but I give them more credit than THAT.
We are doing the machine work for the 3 valve Vette heads and the V10 version going in the HDs. We have been told we'll get a ride in a car with one of the 3 valve setups in the next month or so. I'll let you know if its a gimmick
Originally Posted by pman
We are doing the machine work for the 3 valve Vette heads and the V10 version going in the HDs. We have been told we'll get a ride in a car with one of the 3 valve setups in the next month or so. I'll let you know if its a gimmic k
LSM Motorsports...we are going to be working on most of the valvetrain... cam and springs. Camshafts are our speciality but we are a full machine shop.
I'm not a cam guru but i'll see what i can divulge tomorrow.
When I saw some of the data on the 6.4L GTO concept, it made me wonder if the motor it uses will be similar to the LS7 setup.
Here's what someone posted about it:
All engine parts are from the Gen IV small block family
Engine Displacement: 6.4L (389 CID)
Bore: 105.03mm (4.135”)
Stroke: 92.00mm (3.622”)
REV Limit: 7000 RPM
Peak Hp: 575 Hp @ 6800 RPM
Peak Tq: 500 Lb-Ft @ 5200 RPM
Compression Ratio: 10.5:1
Cam Shaft: Custom GM Hyd Roller
Valve lift: 15.75mm (.620”)
Cam Duration Int: 232 deg @ .050” Tappet
Cam Duration Exh: 272 deg @ .050” Tappet
90mm Throttle Body
Dual Mass Air Flow sensors, Cold air induction system
REV Limit: 7000 RPM
90mm Throttle Body
Originally Posted by Z06Cam
I think you're right on about VVT, but the technology isn't there yet, is it?
and to piggyback on the 3 valve heads from a good source there should be a aftermarket 4 valve head out with in the next few years. but i dont want to realese any info untill that product is actually tested
It doesn't matter. They sucked until recently.
Typical of GM they are releaseing their plans in steps. The 3valve head is step one. What the valve positioning has allowed for, is the ability to place the fuel injector in the head giving the motors direct injection(more power and more efficient ). GM also plans on using two camshafts, 1 for intake and 1 for exhaust. This will also allow them to mimic variable valve timing through a cam phaser that varies the intake cam. So when you add up all three steps you get: a direct injected 3 valved pushrod w/ variable valve timing. Course by the time GM actually puts all three steps together Ford will have its camless motors
If something is better then the other the weaker one dies. That why all cars use hydraulic brakes now instead of the mechanical friction type used on the original horseless carriages. If overhead cam was better then push rod, when GM spent millions design a new V8 it would have OHC. And let us not forget the nut less wonder that is the Ford 4.6. In its first incarnation it was much slower then the push rod 5.0 it replaced.
There are several advantage to multi valve heads, as well as disadvantages. Disadvantages are, cost and more precipitating mass. Causing parastetic loss. The advantages lager total valve size with less shrouding. (Ex. A single 2” valve vs. two 1” valves) and architecture. Allowing for placement of components that would not be possible on a two valve. There havent been any truly original designs on the automobile in fifty years just improvements on old ones
gm spent millions on the lt-5 which is a dohc v-8 dont know why they didnt keep production but they had it and it's alot better motor than the ls-1 it's all about r&d those exotic european cars have ohc set ups and alot of them are fast as **** and run well at the same time.
Race your car!
My biggest ocncern with eh 3 valve head is that the entire thing looks fragile to me for racing purposes, that 2nd pushrod for the exhaust valve is a little scary, and the lifter for the 2 intake valves is gonna have to be really beefy to take the abuse of high rate springs, which makes for a heavier valvetrain. I thought that heavy valvetrain was the one downside of a pushrod motor, it looks like they are making the entire valvetrain even heavier than normal Has anyone else thought about this?
I would assume that the effects of having a heavier valvetrain are more than adequately compensated for by the additional airflow and more efficient combustion.
