Would a LS7 Intake Fit?
Solve the whole problem of whether or not the intake will fit by just getting the heads to match
What do you think those will cost and will the three valve per head design fit on the standard pushrod of the GEN III motor. Trending Topics
i never understood how you ccould have a 3 valve...why not just make it 4...wouldn't you have to use a modular design with 4 cams if you went with 3 valves anyway?
) I would put money on the LS7 heads fitting on your GenIII
